Control valve
/ Control valve #1
tdark
I need a control valve for a 26 ton MTD log splitter. I cannot find any number anywhere. I removed the shaft and the spring and four balls were rusted and pitted. It would stall the engine and I could not move the control lever. I tried removed the shaft and cleaned it, it was rusty pretty bad but now I cannot get the thing back together and now I have lost one of the four small balls. I tapped on the end with a small hammer and it flew apart. It did try to work when I cleaned it and but it was slow coming back. I did not try to split wood but I did get the cylinder to move again. Anyway I can identify the control valve by maybe pictures because I cannot find any info written on it. I cannot even find the data tag on the frame of the splitter. All I know it is a 26 ton MTD and I would say probably 10 to14 years old. I included a picture of the valve less the one ball I lost. I am not sure how to put this thing back together. I may can find the ball if it would be possible to make it work again. Otherwise I will just buy a new control valve. Thanks for any help.
/ Control valve
Would this one work or maybe I would have to mount it another way? I appreciate your help. I will order this one if you think this one works. Tom
/ Control valve #4
Either valve will work.
/ Control valve
THANKS. I will order one tomorrow. I appreciate your help on this. Tom
Caterpillar 600 Series Tractor Parts Manuals (A63117)
Caterpillar 600...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2022 EZ-GO ELITE...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
John Deere 608C (A64119)
John Deere 608C...
