Control levers
   / Control levers #1
square1
Michigan
Ford 1700 4x4 w/ FEL
I picked up a Golden Jubilee and am in the process of draining / changing all the fluids. It had sat outside uncover for 3 years.
Looking over the tractor the two small levers on either side of the operator station (see pics) have me wondering about their use. Likely use of the tractor will be bush hogging & snow removal, possibly some driveway and trail maintainence / grading.
ps. My search function seems to be broken. Point, lift, lever, control, draft all returned zero results.
   / Control levers #2
The lever on the left side turns your pto on and off.
The lever on the right switches between draft control and position control on your 3 point.
   / Control levers
Thank you! re: Draft control, horizontal to engage, vertical to disengage?
72'' skid steer bucket (A53421)
72'' skid steer...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
2015 Ford F-450 Bucket Truck (A53117)
2015 Ford F-450...
