Constructive criticism needed!
   / Constructive criticism needed! #11
I would second Akfish on the Hydraulic blades.
   / Constructive criticism needed! #12
If the intentions of the poster are to dress up his gravel driveway from time to time then the Frontier LP1196 landplane should do the job. This is much easier for a novice to use and will give good results fast. With two angled 8' grader blades you can pull up material from the edges to maintain the crown. The skids will do the brunt of the work keeping it running true so it is an easy tool to use.
Box blades and rear blades with hydraulic adjustments are great too but require alot more skill to use. In the wrong hands some of these tools will cause more harm than good.
Steve
   / Constructive criticism needed! #13
That is a very good point. I have not priced one, but I bet they can't be too expensive.
D.
   / Constructive criticism needed! #14
I built one in March with straight blades 96" to plane for new lawns and pastures. Made it with 60" skids instead of 48" ones. At about 950 lbs it does a very good job flattening fields or yards. I set the blades straight instead of angled since I was not concerned about maintainng a crowned road.
Steve
   / Constructive criticism needed! #15
Steve
That's all well and good, Steve. Pretty much a "one-job" tool, though. I do alot more work with my rear blade than "just" dress up my driveway and parking areas..
AKfish
One major consideration in my book on the boxblade - get a welded top, NOT a bolted one. It is not if but when it will shift and you will want to weld it up anyway. Floating tailgate is nice. Hydraulic sacrificers drives the price up in a hurry. I bought a new frontier last year, I will have to look up the model number.
Yes, please!:)
   / Constructive criticism needed! #17
FWIW, I have a Frontier BB1284 boxblade with hydraulic scarifier teeth and top and tilt hitch. Bought this to use with the 110 tlb but now use it behind my 4520 cab tractor and this is working out very well.
The landplane is very useful smoothing and planing driveways and fields that have been plowed or tilled. Cuts off the bumps and fills in the depressions, most new ground can benefit by its use.
Steve
   / Constructive criticism needed! #18
Steve
The hydraulic teeth and the top n tilt are the "cat's PJ's"! And the top n tilt makes it much easier to work with a box blade (or just about any rear implement), too. But, you're venturing into some real money with those additions...
Yep, the top n tilt helps tremendously with the trial and error learning that goes with a box blade or a rear blade, for that matter.
AKfish
   / Constructive criticism needed! #19
AKfish,
I haven't tried the top and tilt with my #47 7' rear blade yet but might give it a shot in a few weeks. I may want to add a cylinder and setup for angling the blade too.
Just don't have much time of my own right now.
Steve
   / Constructive criticism needed! #20
It's that time of year... gotta make hay when the sun shines! :D (Good thing it's raining here today!)
AKfish
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2013 DODGE CHARGER SEDAN (A54607)
2013 DODGE CHARGER...
CATERPILLAR 226D SKID STEER (A52705)
CATERPILLAR 226D...
Sterling AT (A55301)
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
