TractorGuy
Elite Member
- Joined
- Sep 15, 2013
- Messages
- 4,616
- Location
- N. FL
- Tractor
- John Deere 4310 CUT, Ford New Holland 575E Cab Backhoe (sold), John Deere F725 Front Mount Mower, Kubota LX3310 cab.
Just venting a little but it seems like I work on my equipment as much as I work with it. For example I started the day Saturday changing the front tires and oil on my mower. Mowed the lawn and then adjusted the deck some. Center shaft looks to not be straight with the outboard shafts so that's a repair for another day. Charged up the AC in the backhoe and went over it with a leak detector. Did not find the leak but the charge was gone on Sunday. It has a couple of long hoses that route through the hydraulic lines. All are wet but can't tell where any of it originates because it doesn't drip while running. Will have to try cleaning the undercarriage some time then pressurize with nitrogen and soap it all up to look for bubbles. Sunday I went around part of the property with my 855 and landscape rake. Came in and found the lynch pin missing from one of the lift arms. Dropped the rake to hook that back up. Hooked up the brush cutter and mowed around a section that had grown up. Something got into the PTO linkage and bent it so I couldn't disengage the PTO. Dropped the brush cutter and hooked up the grader blade. (saved the PTO repair for later) Went back around and leveled a section that had a large dip in it. Got in the backhoe and dug a couple of stumps before a hydraulic leak developed. Turned out one of the hoses I installed last week came loose and the o-ring was damaged. Guess I had the 45 degree end turned so it pulled loose. Installed a new o-ring and rerouted the hose. Looked at the radio wiring because it turns off sometimes but did not determine the cause. Came home today and found the bent PTO linkage on the 855 and straightened that. Just seems never ending.
I figure this is typical for having a bunch of old equipment. :confused2:
