constant pull
   / constant pull #1
Anonymous Poster
Epic Contributor
I am wanting to know if using the TC40 hydrotransmission to pull an implement, such as a 10 ft. disc, will cause damage to the transmission or overheat the fluid.
   / constant pull #2
A 10' tandem disc will probably overload the TC40D. Actually, t would probably be too much for a TC40 gear drive as well. The hydro will not pull as much as a similarly powered gear drive tractor.
   / constant pull #3
If you have sandy soil you may be able to do it but it is a lot of disk to pull. I use a 10' with a TN 65 and my soil is heavy with some clay and it works the tractor. I could probally pull a 12' if everything was nice and dry but if I find a wet spot with the 12' I would have to lift it and avoid it or get stuck going thru. Best bet would be to find a 8' transport disc as the old rule of thumb was 5-6 hp per foot of disc.
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2012 Ford F450 Bucket Truck (A50323)
2012 Ford F450...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
