Considering Upgrading.... Looking for the Goldilock's Bucket Size
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #11
Get a light grapple that opens wide with good gullet space. You will be amazed how much brush it will carry compared to a bucket. Learn to position the grapple and curl forward to compress piles down before clamping them. Maybe you can get a grapple attachment that bolts to your bucket.
Single Add-A-Grapple for Sale - Ask Tractor Mike-Ozark, MO
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #12
Sometimes, the solution to a problem is simpler than one might think.
If I were faced with this problem, I would pull a trailer/wagon behind my tractor (or with a SxS) to the work area. Then, I would unhitch and proceed to use my grapple to fill the wagon. Then transport the wagon to brush pile (or other desired location). Empty/dump wagon. Repeat as needed. If the goal is fewer trips back and forth with the tractor, this is the way I would go. Works even better if you can pull with pickup or SxS.
That being said, I think you need more tractor than you have for other reasons...and even more than you are considering. The smallest Kubota I would get in your situation is the L4701.
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #13
We had a B20 for over twenty years and was handy as a pocket on a shirt on our farm. Tried to replace with L3830. No Go. Too big and awkward. Tired several pieces of equipment for mowing what the B20 did was disappointing. Finally got a B26 and couldn’t be happier. Wife thinks it’s hers and that’s OK. Experience has helped buddies get one. Bought both used to save considerable cost.
BXPANDED is about 5 miles away. Many good tools for BX and other small tractors. Amazed at some of the jobs BX owners tackle.
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #14
So we bought a BX2360 in 2014 when we owned 5 acres of flat, river bottom. We are in the early stages of considering a larger Kubota tractor; specifically looking at a B, LX TLB, or L2501 for 11 acres.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
Dimensions - BX2360
Wheelbase:55.1 inches
139 cm
Length:95.5 inches
242 cm
Width:44.5 inches
113 cm
Height (ROPS):70.4 inches
178 cm
Weight:1,322 lbs
599 kg
Kubota L2501 Weight
4WD Gear :2601 lbs
1179 kg
4WD Hydro :2623 lbs
1189 kg
Dimensions - L2501
Wheelbase:63.3 inches
160 cm
2WD Length:110.6 inches
280 cm
4WD Length:106.3 inches
270 cm
Width:55.1 inches
139 cm
Dimensions - MX5400
Wheelbase:74.6 inches
189 cm
4WD Length:125.8 inches
319 cm
Width:69.7 inches
177 cm *
Kubota MX5400 Weight
4WD Gear ROPS :3716 lbs
1685 kg
4WD Gear Cab :4251 lbs
1928 kg
4WD Hydro ROPS :3734 lbs
1693 kg
4WD Hydro Cab :4268 lbs
1935 kg
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #15
For what it's worth, the L4701 is 62.5" wide and weighs about 3300 lbs...so, in between the 2501 and MX that Jeff referenced.
Wow! Tried to respond this morning before work, but ran out of time and coffee. Lots of good points here and discussion and I appreciate the contributions. I apologize as it takes some time for me to put words to paper
In considering a larger tractor I am looking at a lot of different factors: size/weight/lift + volumetric capacity. I also have a decent understanding of what we can afford and what my yard will support in terms of maneuverability and weight induced damage. Those last two factors are what has been driving my specific interest in the large B, Lx & L2501 range of tractors in considering if trading up in tractors would provide added enough functionality for my needs/wants to make it worth the cost&effort.
I would love to be able to afford an MX or Grand L; however they are simply beyond what we can reasonably afford. Also, while weight is a huge factor in considering usefulness, those tractors are simply too large to be easily maneuverable on our property and likely also too heavy for our property.
Things that important in considering whether to buy larger piece of equipment are:
- Increased ability to move larger volumes of light materials (mulch) per trip.
- Increased capacity and ease of brush transport
- Occasional need for the ability to dig and transport larger amounts than I am currently capable of sedimentation from the ditch alongside the gravel road running to the shop
- Occasional homeowner level trenching + excavation of holes for planting/landscaping
- Occasional re-excavation to repair water lines to the house
- Innate loader quick attach, preferably SSQA
- *Higher material transport speed...... Caveat because, based on conditions, it may not be useful/safe
Things that are not important:
- Mowing… is handled by a zero turn
- Heavy ground engagement work
- Woods/trail work
Understand I have read any number of threads on TLB's and their utility vs value curve. Having a backhoe attachment is a significant want and small need for me. The wife and I have pretty hectic work/life schedules. I like working in the yard and highly value being able to work on projects without having to deal with rental companies.
I had an old IH2500b with a 3/4 cubic yard bucket.
I have a PowerTrac PT425 with a 10 cubic foot (a little more than 1/3 cubic yard) bucket and a 5 cubic foot bucket.
The little PT425 with the smaller bucket would run circles around the larger IH with the larger bucket when doing tasks like moving mulch, stone, and other loose materials because it is so fast and nimble.
The IH could squash the little PT425 like a bug because it was so large and strong.
You can’t really compare bucket widths without looking at depths and heights. You need to look at cubic displacement to see which one will carry more material is what I’m trying to say.
Then you need to see which machine can carry which bucket with X amount of weight, etc.
Anyhow, a bit to think about. Good luck in your search.
Moss - you make a bunch of good points both in terms of maneuverability and in regards to what I was looking at/for regarding bucket sizes. What I wish I could find is a listing of dimensions, similar to what W.R. Long provides, for the buckets that Kubota offers on their tractors.
If I had that I could do some caculating to have some hard numbers, which would better help to make a determination if it was worthwhile in terms of wants/needs to get a larger TLB (hopefully with grapple) or just add a 3rd function and grapple to the bx.
We enjoy our B26 as a multi-use machine. 54” grapple is used often. 60”HD gp bucket. Strong heavy duty tractor made for lifting yet compact. Landscaper’s dream. 4 post ROPS and canopy offers good operator protection. Many modifications to suit our use.
I had originally looked at the B26's I really like that they are overbuilt to function in a commercial environment. Pretty early on I had discounted them from consideration based on the MSRP. Would you be willing to ball park what you paid and the year you bought it?
I feel like you're getting what I'm putting down. Weight and power (Loader, hp, 3pt, backhoe) is always a nice thing, but in many cases there's a sweet spot compromise. I'd love to be able to afford an MX and what if offers, but there's definitely places on my property where I need to go that it wouldn't fit.
As example, if I got an MX TLB the power and capacity of the backhoe bucket would be great, but there's no way I could use it to clear the ditches I have because of the clearance on either side of the gravel road on our property. Seat of the pants, a B TLB feels right for what we have....but, excluding the backhoe, if it's a neglible increase in capabilities it might not be worth taking on a loan.
That's the plan regardless of the outcome of my research into a larger tractor.
I don't necessarily disagree with your assessment about the trailer and its something I will consider... The one plus side of using the BX is that while the bucket size means more trips, the tractor's size means that I can get where I need and mostly position the bucket over the bed and dump directly where I need the mulch with minimal spreading. The other thing is that while I certainly could pile brush into a trailer the location of the brush pile largely precludes being able to get a trailer down to it.
I would honestly appreciate hearing your thoughts about why you think I might need an L4701 or bigger...While I have a spreadsheet comparing the specs for B's, Lx, and L2501 I honestly don't know if or how much bigger an L4701 might be. More lift,volume capacity and power would certainly be nice, but if size and weight significantly limits my ability to work in the yard that I have it would be worse than just sticking with the bx.
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #17
I'm a spreadsheet guy, too. I covered 12 or 13 manufacturers and about 3-5 tractors each.
The L4701 seemed to hit a sweet spot between sizes. A little bigger than the frame on the 3301 and 3901, but not as big as the MX series. The devil is in the details. Working on trees can mean having to move more weight with the FEL. Your woods are likely different than my pine plantation. Sometimes, smaller is better. If you want to reduce time in the seat, you will want the biggest tractor that fits your land and has a price you can live with. One reason I will probably not buy Kubota is the lower capacity for similar sized frames.
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #18
- Woods/trail work
Wow. You are really working at it. I've been where you are tractor-wise - but probably not in any way that really counts. And I've never seen your land, but have spent time in East Texas & up to Missouri.
The Kubota M59 TLB was roughly double what our budget was at the time. It's been 15 years, and every time we fire it up my wife can't stop talking about what a good investment it was. Only downside (and I've never said this to her) is that she doesn't want to use it herself because it is just too big for her to feel comfortable with. As good as the size is for projects, if I had known her feelings I would have leaned more towards one of the smaller Kubota TLBs.... like the B26 or L39 whatever the similar model is they are selling today.
On backhoes - we use it more for landscaping, planting trees & shrubs, moving rocks, and as a crane than actually digging ditches or such. If you get one, get a thumb on it. Yes, it costs more.... For years we gardened and landscaped by hand and loved it, but your back does get older and a small backhoe on a little tractor is a wonderful thing for a retired couple.
If you are seriously looking larger like L4701 and a little up, I'd personally look at low hr. used ones of those so you could keep the BX... maybe add an attachmet or two to it. Little tractors are just so doggone handy. I miss our little 16hp Yanmar, and know my wife does too. She never says anything, but now uses a wheelbarrow where she used to use the little tractor.
rScotty
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #19
For that reason alone I kept my BX when I upgraded. It still sees all it's normal chores just don't beat on it to accomplish bigger tasks. There is no way get a 66" bucket into places the 48" just works. Small and narrow is handy in all sorts of ways.
   / Considering Upgrading.... Looking for the Goldilock's Bucket Size #20
In your spreadsheet do you have columns for entertainment and safety with multiple operators? Another reason B26 are popular rentals. Being a safe platform for my wife and father was a major model consideration.
Renting one to test and evaluate might help you? Home Depot, Uhaul, Enterprise.
B26 is 4,000#. Great loader articulation and lift.
The used one we got from a local rental auction had 50hours in 2016. About all options. Saved about $10K than new. The thumb on the backhoe was new option for us. If we had bought new probably wouldn’t have spent extra money on a thumb. Now wouldn’t have one without.
It was an evolution of different tractors over time that’s changed with our needs. Enjoy the journey.
159119 (A60430)
159119 (A60430)
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
XCMG CV83PD (A53317)
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
1762 (A58375)
1762 (A58375)
