Considering the TC
/ Considering the TC #1
jabbahop
Jericho Vermont
2007 Toolcat Turbo C series
I am considering getting a Toolcat for work around our property.
1) long and very steep dirt driveway maintenance - dirt and snow
2) trail and property maint (downed trees, etc.)
3) gardening and landscaping stuff
A couple of questions for the group
1) I don't expect to put tons of hours on the machine - what do people think about used vs new and what should one avoid for in a used machine?
2) how are these on logging trails, hills, and muddy and uneven terrain?
3) In vermont which snow removal attachment works best (plow, vplow or blower? I am assuming the v-plow but wanted others views
4) we have lots more woods than grass on the property (have a 10 acre pasture but that gets grazed by cattle) - should I just stick with our z-mower or spring for the mower attachment - seems like overkill for us.
Disappointed to find out that there are no TC's available until the new series comes out (February) - hope they don't go up in price much.
thanks all.
/ Considering the TC #2
TC sounds ideal for your situation. the v-plow should be fine if you have room to push the snow. Blower works better if you need to move it elsewhere.
I would not buy a used machine myself, but I count on mine to make a living and don't want to deal with someone elses problems. Just around the house i would consider a used machine.
The z mower should be fine for all the small areas (even acres) the TC mower and machine seems a little heavy for the home lawn.
Good luck
Dylan
/ Considering the TC #3
2 things to consider.
1) If you can find a low hr used machine at a dealer and they can demonstrate that all updates and field modifications have been done, I woul certainly consider it. Used can be had at huge savings over new and if all the little glitches are taken care they can be a real bargain. I could do a lot with the $10-15K saved over new. Not that you shouldn't buy new if you want to :).
2) I say this with some reservations..but if you rule out attachmnets with higher demand hydraulic motors (mowers and snowblowers etc). A non turbo machine is not a stupid thing to do. You can still use grapples, augers and plows both V and straight.
/ Considering the TC #4
I bought a used 'A' model with 230+ hours early in 2006. I think it had 465 hours on it when I did the 500 hour service a few weeks ago. The bulk of my hours are from mowing and grapple work. That was the primary use by the original owner as well.
Attachments are expensive. Finding a used one with attachments may save you quite a bit. Mine came with the utility grapple, 72" finish style mower, 66" snowblower and a standard bucket. The 'A' model handles these attachments well. Also, I built a hydraulic pincher that I use for pulling trees and fence posts.
dsb
/ Considering the TC #5
welcome,
plow fastest
blower best if no where to push snow ($$$)
bucket works excellent around buildings/doors
plow on a truck faster for straight long stretches,
tc trumps around buildings/doors
Thanks to all for your advice.
I was able to find a dealer's last Turbo an hour and a half away with cab/heat/AC for a pretty good price so I went for it.
Adding a new V-plow for $2.1K (nice promotion that they were running) and the bucket. I'll see how the bucket works on road maintenance before getting another attachment. Hopefully I don't kick myself when the new version comes out but it seems like a nice unit as it is and I am not likely to be a real hard core user anyway. May be doing some neighbor's driveways for the fun of it ;-)
Thanks again.
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2012 Ford F-450 Ambulance (A64556)
2012 Ford F-450...
Gehl RS6-34 (A64119)
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
