Considering a Satoh Beaver S-370D 4wd purchase
   / Considering a Satoh Beaver S-370D 4wd purchase #11
:confused:I just bought a satoh 370d and have a lot of questions am I at the right place thanks zone cop.
   / Considering a Satoh Beaver S-370D 4wd purchase #12
You're in the right place, zone cop, but you'll be better off starting a new thread for specific questions.
John
   / Considering a Satoh Beaver S-370D 4wd purchase #13
starting a new thread meaning?
   / Considering a Satoh Beaver S-370D 4wd purchase #14
Welcome to TBN! If you have questions about your 370 you are in the right place. What John means is that when you want to ask a question about your tractor, start by going here to the Mitsubishi/Satoh forum and there is a button above the list of different threads or questions that others have asked. You might also try the search feature. The 370 has been pretty well covered here.
   / Considering a Satoh Beaver S-370D 4wd purchase #15
Oh okay I understand.. I will get right on that.. Thank you..
   / Considering a Satoh Beaver S-370D 4wd purchase #16
I have a 370 and the 3pt arms are stuck in the up position. Any ideas what might be wrong?
   / Considering a Satoh Beaver S-370D 4wd purchase #17
Gringo9000, you may have better luck getting specific help by starting your own thread asking this question. However, frequently the lift piston can become stuck in the cylinder bore due to corrosion, and lock in the up position. I've broken them free by putting a lot of weight onto the lift arms, or prying down on them with a sturdy bar. Good luck!
   / Considering a Satoh Beaver S-370D 4wd purchase #18
My 3 point lift cylinder was stuck when I bought my tractor. I had to disassemble the top of the case, whack out the cylinder with a brass punch, and hone (very slightly) the top of the bore. Everything seems to be working ok for now. You don't need to drain the case of gear lube to do this but likely it is old and water contaminated anyway so you may as well.
   / Considering a Satoh Beaver S-370D 4wd purchase #19
Thanks for the information.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
1270 (A50490)
1270 (A50490)
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
