Connect-Under-Pressure, Breakaway Quick Connect
   / Connect-Under-Pressure, Breakaway Quick Connect #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
One of my 3rd function quick couplers failed and needed to be replaced. So I decided to look a break-away option because I have come close to accidentally dropping front implements with the hydraulics attached.
I change implements frequently and currently had to turn off the tractor to relieve pressure and cycle the elctro diverter. I also have to constantly fight to keep the QDs clean as I do a lot of dirt work with the loader.
I came across this Parker product which normally sells for $280 but Blain's Farm and Fleet has it for $130 somehow.
Pioneer Lever Coupler Kit at Blain's Farm & Fleet
-Push or pull one handed to connect or disconnect (ISO 5675 2way mounted couplers).
-Built in shut-off ball valves.
-Built-in sealed automatic dust covers with gaskets to keep out dirt even when connected.
-A drain hole to weep the small amount of hydraulic fluid that escapes with disconnects.
-A clamp bar
It's really slick.
I had to bed the clamp bar to about 80deg for my application.
It was super easy to install (1/2" NPFT).
While I was at it I switched my plugs to a pressure-relief design to relieve pressure build up in my implements line due to temperature swings. You can see the little pre-valve ob the very tip of the poppet (we'll see it these fail easier). But no more fighting the residual pressure ever!
This is definitely a luxury set-up but man is it nice!
   / Connect-Under-Pressure, Breakaway Quick Connect #2
Thanks- all very interesting, and looks like a great idea, especially for someone like yourself, often changing attachments. I hadn't seen those plugs with the pre-relief feature. Cool. Hopefully, they shouldn't give you any problems. These are not "break-away" or am I missing something??
Yes, yank on a hose and it disconnects and seals.
   / Connect-Under-Pressure, Breakaway Quick Connect #4
-A clamp bar
It's really slick.
Luke are these relief valve coupler halves also from Blains?
Lenny
I saw some a TSC too.
   / Connect-Under-Pressure, Breakaway Quick Connect #7
My samurai hedge trimmer arrived and the dealer is willing to attach a 3rd function valve on my 2007 Kubota B7800. However he is quite a ways from here and I think I have the skills to install it myself. I just need detailed instructions on how to go about it. Any help is always appreciated. Hal
"I may not do good work, but I sure am slow!"
   / Connect-Under-Pressure, Breakaway Quick Connect #8
I have those relief valves on the aux circuit of my deere but never understood them. There is a small hole, that I have never seen a drop of oil come out (not that the tree huggers at deere would allow that). So how do they work?
Deere's may function differently but these have a secondary, smaller valve within the popet itself with a smaller surface area (so more PSI when you push on it with the female QD). It relieves enough pressure to depress the larger poppet valve.
   / Connect-Under-Pressure, Breakaway Quick Connect #10
I thought the handle I see in the picture was the pressure relief method. That's what the dealer told me, as I have two of these valves on the 3rd function. My rear couplers are those hellishly complicated (no collar to retract) type. Just press in.
2015 John Deere 5085M (A50120)
2015 John Deere...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
Smoke Daddy Portable Grill (A50515)
Smoke Daddy...
2015 Chevrolet Express Shuttle Bus (A50323)
2015 Chevrolet...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
