Confused
/ Confused #1
wayne mccormick
Iseki 2202
Hi, I have a Iseki 2202 and when sat there is a turn knob under right side of seat. Please can someone tell me what this does. Thanks very much.
/ Confused #2
Frequently in a nearby location, and with a turn knob, is the "speed up - speed down" of the 3 point hitch. So if you're raking a lawn and because the lawn is smooth, you're just flying back and forth, you'd set that knob to allow the mower to drop quickly after you've made your turn (because you don't want to turn with a rake in the down position).
/ Confused #3
G'day Mate and welcome to TBN from Downunder.
As Htwt said, known as the "Rockshaft Rate-of-Drop Control Knob". Adjusted so that your 3 point hitch (3PH) doesn't come crashing down when relieving the hydraulic pressure, via the Rockshaft Control Lever, to lower the 3PH.
Note that a 3PH only raises via hydraulic pressure. Lowering is via released hydraulic pressure AND gravity.
Enjoy the site, from wherever in the world you are.
/ Confused #4
FPNI
/ Confused #5
Well - it's either the 3-point rate of drop knob OR the spring tension control for "rate of bounce" on your seat.
2016 Ford F-450 Ambulance (A64556)
2016 Ford F-450...
2006 Ford F-250 Knapheide Service Truck with Liftgate (A64556)
2006 Ford F-250...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
