Confused
   / Confused #1
wayne mccormick
Iseki 2202
Hi, I have a Iseki 2202 and when sat there is a turn knob under right side of seat. Please can someone tell me what this does. Thanks very much.
   / Confused #2
Frequently in a nearby location, and with a turn knob, is the "speed up - speed down" of the 3 point hitch. So if you're raking a lawn and because the lawn is smooth, you're just flying back and forth, you'd set that knob to allow the mower to drop quickly after you've made your turn (because you don't want to turn with a rake in the down position).
   / Confused #3
G'day Mate and welcome to TBN from Downunder.
As Htwt said, known as the "Rockshaft Rate-of-Drop Control Knob". Adjusted so that your 3 point hitch (3PH) doesn't come crashing down when relieving the hydraulic pressure, via the Rockshaft Control Lever, to lower the 3PH.
Note that a 3PH only raises via hydraulic pressure. Lowering is via released hydraulic pressure AND gravity.
Enjoy the site, from wherever in the world you are.
   / Confused #4
FPNI
   / Confused #5
Well - it's either the 3-point rate of drop knob OR the spring tension control for "rate of bounce" on your seat.
