Confused about wheel motor closed loop circuit
   / Confused about wheel motor closed loop circuit #11
Yes, it has a suction side filter...but it's only 10 micron and filters the make up oil in the closed loop.
To that point however, this tractor does have case drains on all wheel motors. So, it's possible the closed loop does get new oil over time.
This wouldn't be true for my 425 though.
Regarding the filter, I built a filter using check valves that's reversible.
A good 10 micron filter will keep the closed loop system from getting external contaminates.
Did you build it so that your filter works in both directions or filter in one direction and free flow in the other? One direction is how the HST filters I have seen work. Filtering in the forward or most common use direction.
1980 Gleaner F2 with heads (A56438)
1980 Gleaner F2...
Adams Tender / Magnolia Trailer (A56438)
Adams Tender /...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
