Seeders cone style fertilizer/grass spreader
   / cone style fertilizer/grass spreader #1
DemcoEd
Southwest Minnesota
New Holland TC40DA
I've been looking for something larger for spreading fertilizer on my yard. Tractor Supply has these cone style spreaders. Fertilizer Spreader - 2118427 | Tractor Supply Company Have any of you used these or other brands? How do you like them? I live in an area where it seems the wind blows everyday, how does the wind affect the spread pattern?
   / cone style fertilizer/grass spreader #2
I've used baltimatic and herd spreaders. They work pretty good but I wouldnt put out ryegrass seed if its very windy
   / cone style fertilizer/grass spreader #3
I have a similar spin spreader, TurboSpin 450 works well enough I use it for larger lawns and to put out Ironite.
I also have considered something like the ATV spreader shown on the right side of the TSC page. Reason being for things like seasonal fertilizing and amendments I could use the lawn mower instead of running a heaviy tractor across the lawns. Supposedly I could use the cat 1 spin spreader that you are inquiring about behind my x749, I am going to try that out too.
   / cone style fertilizer/grass spreader #4
How big is you’re yard? Are you sure you need a 3pt
   / cone style fertilizer/grass spreader #5
Ed, that is what we have at the farm, maybe not same brand. I spread 10 acres in about 5 hours, this past Sunday. It holds comfortably the 7 1/2 50 lb bags of nitrogen I just spread on one field. I know it says 500 lbs but I would think that 10 bags would have some spilling out the top when I hit the bumps in the beginning, but you may not have that problem in a flat yard. As far as wind I was spreading stuff the size of b-bs, at my recommended speed and setting in the post irene gusts (18 mph) and didn't notice any discernible drift. Ours sits pretty low to the ground.
Now my 2 cents on seed, I use the county Ag no till drill, the amount we would spend on spreading spun seed is astronomical in comparison to $20/ day and $4 an acre to rent it from them. We use less seed that way. Not saying you shouldn't do it, just want to give you another option. Watch videos on it, I am ok with a little roughness on my fields , you may not be ok with it on your lawn. Good luck!
   / cone style fertilizer/grass spreader #6
Those types of spreaders can throw seed/fertilize as far as 25ft depending on size of the seed/pellets, and how high you have the spreader raised with the 3pt lift. I hope you have a BIG yard lol. Wind shouldn't have too much effect on the pattern, unless you're talking some really STRONG wind. Since the material comes off the bottom of the spreader, it's pretty close to the ground. It's not spraying it up into the air, but mostly it just "flies" parallel to the ground.
If you get one, be sure to clean it out thoroughly after each use. The absolute worst thing you can do is run fertilizer through a spreader and then put it up for a year. It will probably be froze up by the next spring! At my hunt club, we usually rinse it out good, and then rub it down with some used oil or diesel.
   / cone style fertilizer/grass spreader #7
i was thinking about getting one of those to over-seed and fertilize 10 acre horse pasture......why don't you buy it and let me try it??? i rate it for you:licking:
If you promise to bring it back to Minnesota by the time I need it, maybe we can work something out:laughing:
   / cone style fertilizer/grass spreader #10
MINNESOTA......I DIDNT THINK YOU EVEN HAVE A SPRING/SUMMER THERE....ISNT IT ALWAYS SNOWING.... HEHE. Sorry for the caps (shout) cause you people are all hard of hearing don't you know.....hehe :p :p
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
UNUSED FUTURE...
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
