Concrete strength
/ Concrete strength
The concrete was for vertical columns. The concrete was to be 4000 psi, it was tested and none was below 3300 psi. The same are 1 footx1footx9 feet long. Four pieces of 5/8 inch rebar, he said 60 or 80. I am not a concrete man to know what that means. Said it had a ring embedded every foot. I am not too concerned about it handling my 1/2 ton pick up or 45 horsepower tractor in the short span. If I needed gravel or a concrete truck it could drive around when dry. Just curious of general strength, I can get them for between $100 to $75 depending on number purchased. He said they weigh about 1200 pounds apiece. Hope that helps some.
/ Concrete strength #23
There are online calculators the OP could use to assess the strength of those columns laid flat as beams. Dunno, maybe they would be safe, maybe not. Need to do the homework.
But only two of the nine would be working, the other seven are just sort of there. So total of 4 #5 rebars supporting the load for $700-$900. The beams have stirrups at 12" spacing which is good. Definitely safe for some loads. not sure I would put my $50k truck or $30k tractor on it.
Concrete and rebar are cheap building materials and easy to work with. If OP wants a concrete beam bridge, why not build it from scratch and make a couple proper beams with 3-8 rebars in the bottom or tension area.
/ Concrete strength #24
The rebar is either 60,000 or 80,000 psi strength. 60 is most common strength
/ Concrete strength #26
Too much guessing. Can never be 100% sure how they are made regardless of claims.
I'd but a couple, they'd make nice footings on either side. The build a proper bridge on top of that
/ Concrete strength #29
Anytime you use something in a way it was not designed for you are walking new ground. Buy a culvert (metal, concrete, or plastic) and be done with it worry free.
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2019 Dodge Durango AWD SUV (A59231)
2019 Dodge Durango...
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
2004 CATERPILLAR 416D BACKHOE (A59823)
2004 CATERPILLAR...
1977 Heil 6,300 Gallon T/A Tanker Trailer (A59230)
1977 Heil 6,300...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
