Concrete placement bucket
   / Concrete placement bucket #31
I think I would just get a load of stone, a load of sand and a few bags of cement and mix my own concrete. Then you can do it at your own pace.
   / Concrete placement bucket #32
It’s not much if any cheaper that way and more running around getting material and having to measure them. It’s easier to just buy a couple pallets of quickcrete. At least it used to be. The quickcrete has went up quite a bit.
I agree. If prohibitive or risky to get a concrete mixer in the site, a large mixer and extra hands is the way to do it.
Like I said, when I was doing my patio, the extra hands and that mixer made it go very quick and easy. Lot quicker than I thought it would've been. In fact, out of the whole project, doing those footers were the most daunting, but because I had the right people and a mixer, it was cake.
Up north of me, there are lots of places I know that were built using a mixer and bags of concrete because it was prohibitive to get a regular mixer truck in or a pumper. With enough help, the finished product looks exactly the same.
I have a small husky mixer but looking at the yardage I need I may look at renting a bigger one.
   / Concrete placement bucket #34
Just get a few bags of Portland cement a few tons of sand a few tons of 57 limestone and rent a mixer for a day
   / Concrete placement bucket #35
I have been driving a mixer for almost 25 years… most recently in western Montana… just yesterday I backed up a steep, 1/2 mile drive with 9.5 yards in my drum… the super was kind enough to drive me up in his pickup prior to my delivery to give me an idea of where I was going and how best to approach it… his truck wouldn’t make the climb without engaging 4-wheel drive… modern mixers have side-to-side and front-to-rear axle lockers… my mixer made the climb, in reverse,with little drama and no wheel spin… the one problem you may have is getting a large, cumbersome truck access to your caissons …unless they’re all in a row there’s gonna be quite a bit of jockeying necessary to reach them… how big (and flat!) is your job site?
   / Concrete placement bucket #36
Anyone ever cobble one of these type of buckets up with useing there current bucket as the base?
I have 18 1'x6.5ft sono tubes to fill and can only get a cement truck about 700ft away. It's about $1000 in concrete bags. Last time I checked 3.5yrd of concrete from the truck wasn't $280 a yard.
For jobs requiring 5yds or less, I mix my own. I usually have piles of sand & gravel around but I'll occasionally buy bags of pre mix if necessary.
I welded an SSQA plate to the frame of an old 6 cu ft. stand mixer I bought at a yard sale. I replaced the burned out electric motor with a hydraulic motor which I power using the 3rd function valve. With the mixer attached to the tractor FEL, I load the ingredients and mix them while transporting to the job site. Pouring is easy using the FEL without having to get off the tractor. It takes around 5 trips to pour a yard but turn around time is reduced by mixing while transporting.
I particularly like this idea because it saves setup & cleanup time. Instead of getting the sand, gravel and cement together next to the mixer, I take the mixer to the components.
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Spinning Target (A57149)
Spinning Target...
2021 TAKEUCHI  TB260 (A58216)
2021 TAKEUCHI...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
Giyi Mini Backhoe (A57149)
Giyi Mini Backhoe...
