Concrete floor help!
/ Concrete floor help! #1
Willman
Southeast PA.
Mahindra 4110
I am looking to pour a concrete floor in my existing 24" x 40" pole barn.
I was thinking of a 5 - 6 inch slab.
I will need to dig out so as to keep the existing door opening height.
These are my questions:
1. How thick should the stone subbase be?
2. Should I just pour up to the outside wall poles leaving a space between the slab and outside steel walls?
3. Should I put a drain in the floor somewhere in the middle?
Thanks for any input you may have.
/ Concrete floor help! #2
Willman,
I just had a little barn built. The slab was poured between 6 and 8 inches thick. I have no drains so it is sloped to the door.
I'd say you would need 4 to 6 inches of gravel below the slab since your not in a foundation. How high is the watertable in that area? Do you need curtain drains under the floor?
If you poured up to the siding would you put a form on the outside?
Regards,
Chris
/ Concrete floor help! #3
</font><font color="blue" class="small">( 3. Should I put a drain in the floor somewhere in the middle?)</font>
As long as the inspector isn't involved, you may get away with it. There are environmental issues with garage floor drains. Gerard
/ Concrete floor help! #4
I put down about 12 inches of mixed stone, tamped at about 6 inches and again on top.
I poured right against my bottom girder, but mine is wood. I don't know about a steel building.
It is nice to have floor drains, but if your local building inspector is involved, he would like to have a chat with you about where they drain to. I know towns in my area are begining to get very strict with any kind of drainage.
Good luck with the pour. If your going to run a power float, be prepared to take it easy the next couple of days. Your body will be sore.
Dave
/ Concrete floor help! #5
4" sub-base should be fine for your climate. the floor drain issue is that is would not be connected to any city sewer system. in case there is a hazardous spill in the building. check with your local codes to be sure. put some plastic 6 mil down on the sub base and your steel mesh unless your using fiber reinforced mix..
2015 HINO BOX TRUCK (A63569)
2015 HINO BOX...
2016 KUBOTA SVL75-2 (A64047)
2016 KUBOTA...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
KENWORTH CAB AND HOOD (A63569)
KENWORTH CAB AND...
2019 CAT 330GC EXCAVATOR (A63569)
2019 CAT 330GC...
