Concrete barrel ballast box idea
   / Concrete barrel ballast box idea
Ok cool, I left it sitting where I poured it. Just finished painting everything, used some left over bed liner for the 3pt hook up so shouldn't be any rust no time soon. I'll share some pictures after it dries.
Thanks again for all these ideas guys!
All done and moved to it's permanent spot with the other implements. Didn't do anymore than snap these pictures & move it, but when lifted I could feel the front end have some pressure relieved. I think it'll be perfect for loader work & moving round bales of hay, not sure I still won't throw on the disk harrows when doing heavy grapple work.
   / Concrete barrel ballast box idea #43
Looks real good. You'll like using the FEL a lot more now.
   / Concrete barrel ballast box idea #44
Weld a large, 3d relief dinosaur foot shape onto the bottom. Lower it occasionally when your are out and leave tracks for the neighbors to find.
Bruce
   / Concrete barrel ballast box idea #45
Bruce
Now I know why there is so much Bigfoot talk in Washington. :laughing:
   / Concrete barrel ballast box idea #46
I'm looking to make one like this for my quick-hitch. This way, it's a fast EZ-on and EZ-off when I need it.
The 30-gallon fits like a glove for the quick hitch. This should be about 240-lbs of rear ballast.
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
