Concrete and Rebar
   / Concrete and Rebar #4
does it come in platnum? (white gold just doesn't have it)
   / Concrete and Rebar #5
That type of stuff is typically used in special applications. An example may be a new foundation on the site of a chemical plant where there is known ground water contamination from years of prior spills. Places that have been populated and industrialized for a long time are typical candidates, since pollution control is a relatively new novel concept... Any of the old industrial zones in our large cities and major cities in Europe would qualify,particularly if ground water movement is slow (clay soils).
If you make the mistake of putting regular steel in those kinds of applications, you will have a short life with a lot of interim maintenance.
   / Concrete and Rebar #6
That's a very fine example of Prokop's first law: Every dumb decision or action has at least one valid reason.:D
   / Concrete and Rebar #7
What about fiber fill? Anybody know the ins and outs about its effect when used with rebar. Do you get more durability [esp in terms of impact and chip resistance] than with rebar alone. Is there any downside other than cost?
Thanks, larry
Thanks, larry
I've often wondered that myself. Don't know.
But that also brings to mind that rebar is avail in fiberglass too (for corrosion resistance). And.......carbon fiber (for high strength, think military aircraft)!
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 Dodge 5500 4X4 Bucket Truck (A52128)
2014 Dodge 5500...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
