I have been working in a friend's shop lately and he has a newer PUMA compressor with a vertical tank. This unit came from his local farm supply store. I like the space-saving vertical tank, AND.........the condensate water drains out better. This compressor is belt drive, 3 HP, 220V, pulls 17 AMPs, and is a Vee-2 configuration. Both cylinders pump in TANDEM, not in series. We have NOT been able to run out of air with this machine, no matter what I was doing, be it blasting out the radiator and the screens on the combine, or running an impact wrench steady while I changed the sickle guards on a 20-foot bean header. By having a belt drive, the motor is generic......any motor of that frame size will bolt up and work, so it's something to keep in mind. I LOVE that vertical tank, it is truly the best idea since sliced bread. The semi-elliptical tank end is a natural sump and it gets every cc of water out when you blow the drain. The tandem cylinder arrangement gets you more air at the lower pressures where you need volume. I've had both kinds of compressors.......several of both kinds.
