Forks Comparison Test--Attachable Loader Forks
/ Comparison Test--Attachable Loader Forks #1
glennmac
Western Connecticut
2003 Kubota L3430
I recently had the opportunity to compare and test screw-on forks against chain-on forks, literally side-by-side, on my Kubota B2910. Of the models I tested, the chain-on forks were clearly superior.
I did this test with Robert Wolff of the Woodbury Tractor Company. This thread was intended to be my digital photo debut, since Robert has a camera. Unfortunately, someone purchased the screw-on forks the day before our photo session, so I'll do my best with words.
Pictures are helpful, so let me first refer you all to two earlier threads on this topic. One was called "Clamp on forks question" begun on 3/26/01 in the Kubota Owning Forum. The other was "clamp onloader forks" begun on 4/3/01 in the Attachments Forum. In both threads there is a picture of Harv installing his screw-on Gearmore forks. In the second thread, jinman posted pictures of his chain-on forks. Hopefully, one of our picture wizards can post those photos into this thread.
I compared the forks in the following categories:
1. Price. The chain-on forks were significantly less than the screw-ons. I was bartering, but I think you can get the chain-ons I tested (and now own) for about $250 plus shipping. All of the screw-ons mentioned in the prior threads were in the $300-$500 range.
2. Ease of Attachment. I would call this equal. Both are fast. Both have a slot you slide onto the lower edge of your bucket. Its the "tightening attachment" that differs. As you can see from Harv's photo, you just tighten a screw for the screw-ons. In the model I tested this was a little clumsy because the horizontal handle on the end of the screw would alternately bump into the fork housing in one direction and into the back of the bucket in the other direction. The handle is slidable, but is was a little difficult to get good leverage on the slidable handle to do the tightening. With the chain-on variety, a chain wraps completely around the bucket and is tightened with a load binder. See jinman's photos. The first time you do this, you have to experiment with which links to put the binder into. After you figure that out, the process is probably a few seconds quicker than tightening the screw on the screw-ons. With either model, the total time is literally 30-60 seconds per fork.
3. Positioning on the bucket lip. The screw-ons can be positioned anywhere on the lower lip of the bucket. You have less flexibility with the chain-ons because you cant wrap the chain where the loader arms connect to the bucket or where you have welded hooks or other obstructions on the top edge of the bucket. But, for me, I can get the chain-ons postioned in enough places--close together, far apart--to meet any need I see.
4. Security of attachment. This was the BIG BIG difference. The chain-ons attach tight as a drum whereas the screw-ons are wobbly. More specifically, if you apply downward force on either model, as with a load you are carrying, they both are secure in the downward direction. But if you apply upward force on the screw-ons, they have travel. They give. When I was just driving on my lawn with the screw-ons, they bounced around and clanked so much because of this upward give that I was afraid they were going to damage the lower edge of the bucket. Now, the screw-ons I was testing were different in one respct from Harv's. You can see that on the base of his screw, there is a flat plate where the screw meets the bucket. My set didnt have that plate. I think the plate might help the tightness of the connection. But there is simply no way that a screw can apply pressure across the whole bottom of the fork that is underneath the bucket. There is inherent tendency for wobble with upward force. With the chain-ons, however, the tightening force is distributed in all directions around the whole bucket. The forks cannot go down or up if they are properly tightened. As I say, the chain-ons are tight as a drum: no wobble, no clanking. There is also side to side movement on these forks. In other words, if you push the ends to the side, they will move. But again, the chain-ons were much tighter against side-to-side movement. This difference it tightness was the whole ballgame for me--I would have bought and paid more for the chain-ons for this reason alone.
5. Potential for bucket damage. This is related to the attachment mechanism, and I believe the chain-ons are superior for the same reason. With the screw-ons all the force and leverage is on the lower lip of the bucket. With the chain-ons, the force is distributed more evenly around the bucket. The weak point, if any, would be the upper edge of the bucket, which I am having reinforced for this and chain hook reasons.
6. Load stops. You will notice that Harv's forks have vertical load stops, and that jinman's chain-ons have no load stops. I think load stops are important. One is safety, because something like a log could roll right along jinman's forks, up the chains like ramp, and into the driver. I am sure he is aware of his and takes precautions. The second reason for load stops is so you can pile a lot of stuff like brush on the forks with out it sliding off. My chain-on forks have 24" load stops, which seem to be significantly longer than Harv's. The higher the load stops, the higher the pile of brush you can carry.
7. Size, weight, strength. The screw-ons I tested appear to have about the same dimensions as Harv's. My chain-ons are at least 8" longer and 2" wider than the screw-ons. I think this is better: I can carry a lot of brush on those long forks, which are obviously made to fit on much larger buckets than my 2910. (The forks are so long that you may not be able to dump them completely on a very small compact tractor.) The chain-on forks are also hollow, unlike the screw-ons, which were solid metal. Therefore, the chain-ons, though larger, are actually slightly lighter in weight than the screw-ons. They are rated at 1500 lbs load, which is more than my loader can lift. As to material, the screw-ons were painted metal, which began to show rust on the paint-stripped areas after being left out in one rain. The chain-ons are coated with "top grade TGIC polyester urethane powder," whatever that is, and seem to have much less of a potential to rust.
I of course cannot speak for all screw-on forks and all chain-on forks, but of the models I compared, it was not even a close call. I believe Robert is now going to be recommending the chain-ons, and you can get them through him.
One last thing about the chain-ons. I found the load binder that came with them to be too big. The binder itself was longer than the mouth of my bucket and was therefore difficult to tighten properly. (This is also probably related to the fact that the forks are aimed at larger average bucket sizes than mine.) Being a nitpicker, I belly-ached about this and Robert got me a smaller loadbinder. I don't know the name--Robert would--but it works perfectly. It is not only smaller, but it is the kind of load binder that inserts into the chain link instead of the usual grabhook kind that goes around the chain link. This is better for two reasons: there is less of a tendencey for the binder to twist the chain, making the attachment more secure; and, secondly, you can insert the binder hook into a link so that it is over or under the next link. This is hard to explain, but the essence is that you can fine tune the tightness about 1/2 a link at a time rather than just one link at a time. In short, if you have a smaller bucket and want chain-on forks, I recommend you order them without the large load binders and buy shorter ones instead.
This was long but hopefully helpful to someone in the future.
/ Comparison Test--Attachable Loader Forks #2
Glenn -
A summary of all your recent comparisons and observations might make for a good couple of chapters in Muhammad's book. Unless you want to compete... /w3tcompact/icons/wink.gif
In keeping with the trend towards in-line graphics, I'll include the clamp-on fork picture you are referring to here:
These are the only forks I have ever used, so I'm in no position to offer any comparisons myself. I will toss in a couple of personal comments, based on my own experience, though --
Ease of attachment -- My screw handles, even when slid all the way to one side, don't interfere with the load stops or the back of the bucket. They can bump the side of the bucket if I postion the forks that far out. And you're right -- about 30 seconds per fork, probably less taking them off.
Security of attachment -- I can't relate to the movement you experienced with the upward force thing. Might be just enough difference between brands to make the difference. I have no bouncing or rattling of any kind as I take my tractor through the steeplchase I call a tractor path on my property. I do notice that they are fairly easily pushed sideways, or rather "skewed", usually when I'm trying to pick something like a log right out of the dirt. Not a huge problem, but occassionally annoying.
Potential for bucket damage -- this was a great concern for me when I first started using the forks 'cuz as you point out, you have all that leverage focused on a relatively small area of the bucket lip. Empirically, though, it has become a non-issue. More than once I have attempted lift things right out at the end of the forks that turned out to be too heavy for my loader. The bucket showed no hint of deformation. Thems is some pretty tough lips. /w3tcompact/icons/wink.gif
A caution here -- my LB400 loader is a little wimpy in the biceps, so it's possible that a more macho loader might have the strength to hurt itself with this fork design, especially if you get the longer ones.
Load stops -- definitely an important issue. Mine are there, but sufficiently short that I have already managed to drop a log on my head (well actually, my hood). That was definitely an attention lapse I have no intention of repeating. I am currently cogitating some sort of vertical extension, not only for better support and safety, but to aid in the transport of big loads of loose brush. I think I want to make them detachable 'cuz my small forks are already 90 lbs apiece, which is just about as much as I care to tote around by hand, thank you very much.
Like I said, I have never used any other forks, including the chain-on kind. In fact, I bought the ones I have sight unseen and had them delivered along with the tractor itself. Sometimes ignorance is bliss. /w3tcompact/icons/crazy.gif
Harv,
Thanks for supplementing my post. Pictures are so helpful. I wanted to show the forks next to each other on my bucket. Oh, well.
I think your forks are designed better than the ones I had. Your bucket also seems larger than mine. More room to turn the screw. I have a sort of ridge underneath the lower lip of my bucket that also seemed to interfere with the ability to tighten down the screw-on forks.
The stress on the bucket will probably only be an issue for really heavy loads like rocks. I will be rolling rocks on my forks, so it worried me. I believe Woodbury Tractor welds an additional plate on the bottom of the bucket when they have sold the screw-ons.
/ Comparison Test--Attachable Loader Forks #4
Does anyone have a site address to see the chain-on forks? I had only considered the clamp on's until glennmac's post and now have to see these. David
Sailorcrew,
For the particular forks I have there is no website. They are made by some small metal shop in Pennsylvania, I think. There may be websites for some other brand.
/ Comparison Test--Attachable Loader Forks #6
Hmmm....
I have a set of clamp on forks. As you noted, they were somewhat expensive ($350 shipped). My experience with them is quite at odds with yours. I find that they are _very_ secure when properly mounted. No up, down or sideways shifting in use. I have used them for picking up granite billets and curbstones (see the attachment for the a picture of the billet, in the grip of my backhoe, but subsequently relocated with the aformentioned forks). I've also used them for unloading my 6 foot rotary cutter and 5 1/2 foot box blade from the delivery truck. I found them excellent tools for the application to which I have put them.
I have no experience with chain on forks and can't comment on the relative merits. I'm happy with my choice, though I have yet to use them for moving brush, which was the primary purpose for their acquisition.
Matthew
/ Comparison Test--Attachable Loader Forks #7
Glennmac,
As usual, a very thorough and thought-provoking post. Those pallet forks look like an acceptable and less-expensive alternative to a grapple. One question . . . can you just drive them into a brush pile and pick it up, or do you have to pile it on them by hand?
/ Comparison Test--Attachable Loader Forks #8
Fishman,
I don't have the attachable forks but the quick tach ones for my JD and I do like you described. It doesn't work as well as you would think because everything tumbles off the sides and there is any to hold it on or down. It does work good to pile brush really though.
/ Comparison Test--Attachable Loader Forks #9
<font color=blue>can you just drive them into a brush pile and pick it up</font color=blue>
Yep, that's the way I do it with my 4' forks; very carefully though after dragging enough brush along both sides of the tractor to rip the valve stem right out of the right front wheel about the second day I ever used the forks./w3tcompact/icons/frown.gif
Bird
/ Comparison Test--Attachable Loader Forks #10
BTW
I have a quick attach bucket bracket (kubota not bobcat)and have priced the kubota 36" pallet forks to use interchangeably with my bucket. They are significantly more money ($894). The only reason I consider them is b/c I have the quick attach to change back and forth with. These options sound much more economical.
Just thought I'd share FYI
Leef
/ Comparison Test--Attachable Loader Forks #11
Leef,
You're right way cheaper route. For the quick tach hookup and the forks it was $900 for my 4600. One thing not mentioned though is center of gravity. I had thought about the loader forks but with those I would have been almost 3 foot past my loader arms with the weight I would be carrying. With the quick tach ones I'm right at my forks, thus I can lift more and lift it safer. My main reason for them is carrying and moving around big round bales. I don't think I could have done it with the chain on or screw on mounts. For most applications though I think they would be ok.
Fishman,
Well, two things. First, when you're cutting something up or clearing brush and you want to carry to the brush pile, you can pile a lot more brush on the forks than in the bucket alone, which was my only option before. Second, if you have an existing brush pile, you can drive the forks in and lift stuff. But, you know, as you lift some of it falls off and you have to pile it back on. Sort of depends on what's in the pile. But, again, its a lot better than a bucket alone. I suppose a big grapple would grab a lot of stuff out of a pile better, but the tradeoff would be expense and probably connection time.
Yes, you have to be careful with balance and center of gravity. You can definitely pick up heavier loads with quick-tach pallet forks.
There is another way the attachable forks help. There are rocks that I physically couldnt get in my loader. The loader could lift them, but couldnt fit or balance the boulder in the mouth of the bucket. With the forks, I can put them flat on the ground and pry the rock up near the bucket. Then curl up the bucket so the rock is essentially in (or on the mouth of) the bucket. Then I lift the rock. So the center of gravity is basically in the bucket. I wouldnt try to lift the same rock farther out on the forks alone.
/ Comparison Test--Attachable Loader Forks #14
For those of you who have forks, what do you use them for? I'm guessing not for moving pallets.
I've heard brush and picking up rocks so far. I'm trying to figure out if I need to add these to my never ending list of attachments.
/ Comparison Test--Attachable Loader Forks #15
Hayden, I actually don't use mine very often, but I've moved brush piles with them, and the rest of the time, yes, I use them to move pallets. I have a bunch of pallets stored in the barn (various sizes) and I used the forks on several occasions to move bricks I had stacked on pallets. I also have a small pallet that my 55 gallon diesel barrel is sitting on, so when I need diesel, I just pick up that pallet, barrel, and all and set it in the back of the pickup, then when I get home set it back out.
Almost forgot the old chicken pen that was built onto the barn. There were two good solid steel posts set in concrete at the outer edge and the rest was a wooden framework with chicken wire on both the sides and the top. A lot of the wood had rotted, but those steel posts were solid as could be. I knew it would be quite a job to cut up, and tear down all that by hand, so I just rammed the forks right through it, lifted it up and over the steel posts, dragged it away from the barn, and crushed and compacted it all I could with the forks, then loaded it on the trailer to haul it off.
Bird
I'm planning on using them to carry lumber, culvert pipe and posts. I also will be using them to carry balled and burlapped trees that I am planting and transplanting. You can also reach into the hole with the forks after you have put the tree in it to jigger the tree into a vertical position. I'm talking larger trees, where the root ball can be hundreds of pounds.
All in all, I wouldnt plan on using them that often. So I was pleased that the more effective forks (of the ones I was testing) also happened to be the least expensive.
/ Comparison Test--Attachable Loader Forks #17
Ditto what everyone else has said. I also use them for carrying round bales and square bales. I have a platform that I put on mine as well to do work high up and carry tools. Works good for that as well.
/ Comparison Test--Attachable Loader Forks #18
I've had chance to use mine a LOT, of course I'm cleaning up after a land clearing operation. Leftover log lengths, trunk ends, crotch pieces. All the pieces left behind from the logging. I find the clamp-ons quick to use out in the clearing. One piece, no parts to lose in the brush when I need to remove 'em and set them aside.
Ya makes your choices and ya takes your choices. /w3tcompact/icons/smile.gif
I also used them to quickly pick up the limbs and the rest of the tree that had broken and fallen on my driveway last winter without having to drag it and gouge up the gravel drive.
Last summer my wife's stepdad had lost a lot of hay to the excessive rain we had and I ended up with 180 bales that I use for cover on a newly bulldozed area that I had. Moved all the bales out thru the area from where they had unloaded them on my driveway using the forks to carry more bales at once than could fit into the bucket.
Up here in ME I've been taking down an old horse corral fence using the forks for carrying the railboards and the posts as I take them down.
Also used them when I had to move a large doghouse to new location and to unload my rollaway when it was delivered by truck and the punk kid driver wouldn't assist me in getting it down after informing me that his tailgate lift was broken.
Alot of this stuff can be accomplished with the fel bucket, skidding tongs and chains, and 3 pt carryalls but different attachments can be a real timesaver and certainly can help make your tractor more useful.
DFB
/ Comparison Test--Attachable Loader Forks #19
DFB, those look like pretty good clamp on forks. I can't quite make out the brand, who makes them?
Thanks,
Joe
/ Comparison Test--Attachable Loader Forks #20
Joe,
There is no "brand name" on them. Just your basic black paint./w3tcompact/icons/smile.gif
I ordered them thru a dealer in NYS and they were delivered UPS to my place in VT from here.
http://www.ringofarm.qpg.com/
DFB
2020 FREIGHTLINER CASCAIDA 123 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2020 FREIGHTLINER...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
iDrive TDS-2010H...
1996 Geo Tracker SUV (A60352)
1996 Geo Tracker...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
