Compact Tractor FEL build
   / Compact Tractor FEL build
I just spent 2 days beating the heck out of myself and the loader. I had to clean up some burn piles full of ash/metal/nails etc. Basically the remnants of 2 barns and a house trailer. Also had to move the cut up house trailer frame (20' sections), a motorcycle that was cut in 3 sections and tear down an old block well house (and cap the well with a piece of concrete). Would have taken me a week by hand and I only spent a couple hrs with the loader.
Though I didnt build it for digging, I was able to dig down about 3" per scoop so I could make sure to get all the nails. My biggest problem was traction, with only 2wd and unfilled tires you really have to use strategy. I did put a 100# steel weight on the back of the grader blade to counter the front weight when tipping (and considering I was dumping over a 30' cliff I was glad). I never had any problems shifting and nothing bent no matter how hard I jammed in. I do need power steering :thumbsup:
The solid lines are all 3/8" brake line from the farm store. I would far prefer a harder steel, the brakeline bends wayyyy to easy. I had a piece of metal grab one of the lines and bend the heck out of it. I need to look around and find some better tubing and redo everything.
As far as even lifting, I just left the cylinders loose at the one end when I hooked it up for the first time. Then I ran them all the way in and out several times until they had filled and vented themselves. Realy wasnt hard if you take some time and have petients (something I usually have little of)
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
1274 (A50490)
1274 (A50490)
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
CAT 973 (A47384)
CAT 973 (A47384)
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
