The telehandlers are very neat, but I can't help wondering about alternatives.
Your budget would also buy nice machinery in the nearly new market.
For example You could buy two machines that both come with spacious cabs, AC, and give yourself the advantages of a known product with local dealerships and technical support. This would give you an easy way to educate yourself on what features you need.
One machine could be a low hour construction loader/backhoe ike an JD 310SK. This type of machine has the safety and capability that comes with size. As nifty as a telehandlers are - and I love them - a construction backhoe will easily perform many of the same chores in comfort. There's good reasons why TLBs are so popular all around the world. A spacious cab is nice. Your back will thank you for touches like an air-suspended seats and the optional "comfort ride". Filtered air and sound isolation good enough to listen to FM radio, too.
And to that machine could be added a second which would be any of several name brand cabbed 100 HP Ag tractors for the 3pt capability. Simply pick one that you like the looks of. The market is full of these large reliable low hour Ag tractors. from the mid 90s on up. Like the TLBs, Ag tractors also have the heavy construction and size to isolate you in AC comfort from whatever carnage is being worked by the three point implement being towed behind you.
You couldn't buy both of these machines new in the budget you've posted, but I think low hour used ones could be had by a determined salesman. It would be interesting to see what your local dealers could come up with. Unlike telehandlers, these types of machines have dealerships most everywhere which creates an active used market with a known used value. So that in the future if the perfect telehandler came along you coud sell out and make the switch. That would not be so easy to do in the other direction.
It's worth thinking about...
rScotty
First, I want to thank you for taking the time to write this. Thoughtful, constructive input is really helpful, as this is not an easy decision process.
There are two sides to what I need to do. The first would be best filled by a tractor, of that I have no doubt. For managing pastures, tractors seem ideal. But I only have 12-15 acres of pasture at present. The other ~175 acres is planted pine forest.
I'm not sure a back hoe would work very well for that part. Some areas of the forested land are fairly open (12-15ft spacing)and level, and I suppose a back hoe would work in those areas. But, others are fairly tight (8ft spacing) and on a slope.
It was suggested that I get a CTL for managing the forest. (though I'm not sure how the the CTL would do on the slopes... Skids steers are tippy, but maybe a CTL is less so?) Xfaxman's numerous posts on what he does with his telehandler are what got me looking at these. They are small, maneuverable, have better FEL capablites than even the CTL, and seem to be well suited for the forestry portion. I'm sure they aren't as good as a tractor for pulling, but they do have hitch capabilities, out weigh my 45hp tractor and though they don't have a pto (in this size range) they do have rear hydraulics.
So, I don't know. I might be better served with a used CAB tractor and a CTL/skid steer. But my mechanical abilities are poor, and I worry about buying used equipment, both from a maintenance standpoint and from the standpoint of recognizing a lemon...
