Buying Advice Compact Cab tractor for vineyard work.
/ Compact Cab tractor for vineyard work. #21
A 25 degree slope is pretty steep. You said you have little tractor experience - be careful!
/ Compact Cab tractor for vineyard work. #22
I spent a lot of years farming some steep ground in the Hudson Valley. But I saw apples along RT 16 between Taylorsville and Wilkesboro yesterday and for the life of me I don’t know how they spray them.
/ Compact Cab tractor for vineyard work. #23
Most/all of the vineyard tractors have more hydraulic capacity the compacts (12gpm vs. 8gpm or so). important for running hedgers and other implements. Was expecting to see compact with a shuttle shift have more implement flow than the comparable hydro. Doesn't seem to be the case? Anyone know why that is?
Because compact tractors are not designed for operating hydraulic powered equipment. Large capacity hydraulics requires more than just a bigger pump. They need larger hydraulic oil reservoir, increased cooling, more power to run the pump and so on. It gets expensive fast so that is why compact tractors doesn’t have it. For a new member asking for advice you might want to check the attitude at the door. You asked for advice and people are giving it. If you don’t like the answers, don’t expect people to give you different answers to satisfy your predetermined specifications.
/ Compact Cab tractor for vineyard work. #24
Do you need a "creep" gear? I help out on a veggie farm, and the tractors we use have ''creep" gears or are hydrostat. Standard Ag tractors don't go slow enough for planting and harvesting.
The gear tractor, Kubota M105S dual speed, is my favorite.
Unsure about the creeper gear. Am guessing "no" but will ask others.
I truly appreciate your time and efforts to provide information. Don't mean to sound ungrateful in the least. That being said, there are some things (like needing a loader) that I cannot change. I am trying to find a tractor with most of the characteristics of a narrow tractor but need to meet a few other goals.
Was looking at the Kioti NX line. Hydraulic flow is 16.5 (shuttle), 65" wide (w/o loader). Probably only 10gpm to the implements- not great. It does have a cruise and PTO cruise (?) which would likely be nice for spraying, etc.
/ Compact Cab tractor for vineyard work. #26
I'm sure there are lots of regional differences, but I'm in the middle of a huge orchard and vineyard area. Seems like the most common tractors in use are 3 and 4 series cabbed John Deeres.
/ Compact Cab tractor for vineyard work. #27
Thousands of acres of vineyards around me. The professionals go with vineyard models which usually start around 60 hp. and go up from there. All are cabbed because of the large amount of spraying; most are 4wd even though the land is pretty flat. They also tend towards Ag tires. While there is every sort of dealer in the area most of what I see in the vineyards is Case-NH or Deere, a few Masseys. As previously mentioned narrow tractors and loaders don't go together well, I would be leery of any dealer selling that combination unless it was a smaller, lower hp model intended for the play farmers. That will rule out air blast sprayers which are a necessity for larger operations.
I do have a narrow, small, low horsepower Deere for maintaining 15 miles of Christmas tree rows. Good for a small brush hog, lousy for spraying. The R4s aren't my first choice as this land gets very greasy. If you opt for a small tractor that doesn't weigh much Ag tires might be the better choice. I think it will be hard to find everything you want in one machine.
/ Compact Cab tractor for vineyard work. #28
IF you are offended, that's on you!
Most guys here are "play farmers", I have no way to know if you fit that mold or not, without bringing it up...
I stand by my post, IF you want to be serous about making money, then buy the RIGHT equipment the first time!
There's always buying used, to fit a tighter budget!
There is over a thousand acres of orchard/vineyard/veggie farms starting 1/2 mile east of me, you won't find even one compact tractor working them...
Kubota isn't the only one making narrow tractors!
SR
Why does it have to be classified as "play farmers"? I have a small 35 acre "farm", but I'm basing it on an old time "family farm" operation with its sole intent on being self sufficient as much as possible. I understand the term "Hobby Farm" and it seems to fit my place even though I can't say I'm fond of the term.
My point is, you don't have to be a like the "big boys" to get exactly what you want out of farming. Every situation is unique and we all have a need for certain equipment. The op, like myself, has a limited budget and looking for advice on ones he mentioned. He's not on here looking for life advice and your definition of what real farming is.
To the OP: Have you looked at the Bransons? I'm in the middle of my research and looking to purchase within the month. We have a lot of Branson dealers around and I'm becoming more impressed with the Branson tractor and the features you get for the money.
/ Compact Cab tractor for vineyard work. #29
Because IF you aren't "trying" to make money at it, you are just play farming.
I never said there was anything wrong with it, I just was suggesting to him how to avoid it!
He said he doesn't have the money for a proper tractor, wait until he see's how much money he has left after play farming!
SR
/ Compact Cab tractor for vineyard work. #30
SR
That reads as a pretty coarse statement but there’s a boatload of truth there.
My ex neighbor up in NY was a wealthy bond broker that had a nice little place in the country then bought the adjoining farm and got into the purebred Angus business. After about 8 years he sold the cattle and machinery. He told me he figured out it would be more fun to take that $200,000 the farm was costing him and buy a Porsche. Drive it for 12 months, wreck it and do it again every year.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
2002 International 9200i Truck (A61307)
2002 International...
(INOP) 2015 POLARIS SPORTSMAN ACE 570 (A59823)
(INOP) 2015...
John Deere 3038E (A60462)
John Deere 3038E...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60352)
2014 International...
