Oil & Fuel Compact 4500 Fuel Line problem
/ Compact 4500 Fuel Line problem #1
99k1500
Oklahoma
TC55da
Working on my fathers 4500 tractor
The fuel line on top of the filter / separator ( AM879740 ) simply popped off!
The fuel line at the top of the separator has a t line that must have some kind of static fit popped out of the top of the filter.... The portion of the "T" has two grooves that go half way around that probably has / had some kind of retaining locking ring.
Obviously when this happened fuel went everywhere. Is there a fix or simply replace the entire filter separator $90?
It is the line "T" at the very top of the filter in this image found on ebay.
John Deere Fuel Filter AM87974 45 451 46 461 47 471 | eBay
Any help would be appreciated.
/ Compact 4500 Fuel Line problem #2
I'd replace the unit..
/ Compact 4500 Fuel Line problem #3
Most likely a press fit. If you want to try to get away cheap you can try loctite and press it back in. Maybe try to expand the male end to get the tight fit again. A green loctite would probably hold for lifetime.
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61573)
2010 Ari Hetra...
Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
