Common rail vs mechanical injection
   / Common rail vs mechanical injection #121
When it’s that cold I don’t care to start either.
   / Common rail vs mechanical injection #124
If extra time for the grid to superheat the intake air to 284F is unaided or that diesel antigel for winter is unaided.
Then I guess the heated garage and hot block starts are unaided too?
Those grid heaters are great for killing batteries where it gets cold. Almost 2kW at over 200A for 30 seconds is always a good time.
I am fairly sure you are better off using your block heater, then at least you still have a chance to start when the grid melts its power relay. Or at least extending its life somewhat.
   / Common rail vs mechanical injection #125
No doubt and I’m glad I will never have to try.
Abuse and Cruelty to diesels!
   / Common rail vs mechanical injection #126
   / Common rail vs mechanical injection #127
After -45C cummins really need to get plugged in or you are staying home.
I do not plug mine in unless its -20c. Synthetic oil is worth every penny.
   / Common rail vs mechanical injection #128
Impressive video. Thanks for showing another reason to love my Cummins diesels.
   / Common rail vs mechanical injection #129
Its the reason I started loving cummins, a coworker on a pipeline job was starting his at -25C not plugged in….. but no grid heater, he did not realize you had to wait to start, he would just turn the key past. I figured if the engine lasted as long as it did with no special treatment and no repairs, that was the engine to get. Fleet trucks get fleet abuse unfortunately.
We also had another guy trip the Positive Air Shutoff at highway speed. Truck still lives.
   / Common rail vs mechanical injection #130
While they may well start unaided at those temperatures why be that rough on an engine.
Plug the poor thing in for an hour or two, get the frost out of the block.
The grid heaters and hi pressure common rail systems are good cold weather starters.
My little eco-diesel always amazed me at how good it would start in cold.
Of course the additives and blended fuel that the engines are fed with at those temperatures helps abit also.
But if possible I plugged all my diesels in for cold weather starts, they sound and behave so much better.
Those that don't wish too that's your business just don't tell me it's not needed because it may not be necessary.
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
44052 (A55852)
44052 (A55852)
International 454 Tractor (A59814)
International 454...
22FT Roadway Dry Van Pup Trailer (A56438)
22FT Roadway Dry...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
