comer finish mower
/ comer finish mower #1
titan307
yanmar ym1500
hello everyone newbie here. first off just want to say i really like the board. next i wonder if anyone can tell me what type of oil or does oil even go in the gear box on top of the mower and how much. just got the mower and it did not come with book and cant find a site for me to ask. any help would be appreciated as its almost time to start cutting.
/ comer finish mower #2
Is this a new mower? And, the dealer didn't have a manual?
Well, the gear box does require oil. It's probably 90W gear oil. You should see a plug on the side of the gear box. Also, look for one on top....may be one there, but should definitely be one on the side. Remove those plugs.
If there is a plug on the top, fill through that hole. Otherwise, use a funnel and fill through the side hole. When you see oil draining out of the side hole, it's filled.
I suggest you ask the dealer, but I suspect it's one of those Chinese brands that get renamed to sell in the USA.
Did you get a warranty with this unit (if new)?
/ comer finish mower #3
I have a pto shaft from Comer. They are italian. Try www.comergroup.com I found a link to a finish mower at Finish mowers but things are listed kind of weird. Like mowers are listed under Land Preperation machines.
Butler MFG Water Tanker (A63118)
Butler MFG Water...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
24" X 84" METAL SHELVES (A63745)
24" X 84" METAL...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
YARD MULE (INOPERABLE) (A63569)
YARD MULE...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
