Combo Base frame / material handle tine attachment
/ Combo Base frame / material handle tine attachment #21
WOW, that is some quality work, and I like how you have executed it. Could we see a picture of the quick hitch parts. I would like to design this for my tractor and could use some ideas from your project. Thanks Jason
The quick-attach part really just duplicates the John Deere quick-attach bucket design. Is that what you'd like a picture of? I implemented it a little differently than they did, but close.
Once the Base frame is quick-tached on, the gin pole bolts onto that, or the Personell Lift can be driven up to, lower tines slide thru pipe section receivers on the Lift, and I add two bolts. I haven't actually assembled the Lift since painting, but will be soon to do some tree trimming. I will try to get a picture of that then.
If you can describe which other details interest you, I will be glad to show more detail.
/ Combo Base frame / material handle tine attachment #23
Yes, I would like a picture of where the quick tach connects with the base of the fork or the back of the loader bucket. I'm interested in how it attaches so I would have an idea of how to contruct one. For instance, does the base part of the implement go into a 'cup' or something like it and the top of the base gets a pin through some hole to lock it into place? I would like tocontruct something that is easy to connect/detach yet stong enough not to come undone.
Once again I would like to say nice job, I can appreciate the work that went into it.
/ Combo Base frame / material handle tine attachment #24
Jim,
I can only echo what others have said here. Outstanding work. Very well done and THANKS for sharing it with us.
Hoss
/ Combo Base frame / material handle tine attachment #25
jasonf Thanks for responding.
"When you see the box with the red X in it, I always do a right click then click on SHOW PICTURE, not PROPERTIES. The picture then appears. Have you tried this ?"
Yes Jason, I've tried that. Sometimes it works and sometimes not. It's got me baffled.
At any rate, I on my home puter now with W98 and everything is working fine. The pictures are great and the work is simply outstandig.
Thanks Jim for sharing. Really quality work there. I'll definitly be experimenting with some of your ideas.
micromike
Here is a photo showing some of the details you may be looking for Jason. Another photo will follow. It may be necessary to go to a JD dealer to get the whole idea. Ask if questions...
Here's another shot. This shows it attached to the loader boom. Notice the Lynch pins at the bottom, dropped through the machined stub shaft pcs.
I made the upper curved receiver fittings by starting with some 1" pipe sections. and once the shape was obtained, I added the huge gussets you see, on each side of the pipe sections. Those gussets go down inside the front of the vertical channels, are welded vertically to the channels. Hopefully you can see how my solution is probably overkill compared to the JD stock bucket fittings. They used a couple of pcs of formed flat iron. Sometimes I get carried away, all in fun.
/ Combo Base frame / material handle tine attachment #28
Jim,
Very nice work! Your work makes me envious of your skills.
There have been discussions here on TBN about welding but none of them really stirred any motivation to learn to weld, until this. Now have a new skill to learn this year.
/ Combo Base frame / material handle tine attachment #29
I disagree, the stock JD piece is not heavy enough. Your soultion looks much better !!!! Thanks for taking the time to get the pictures to me. I have saved them and will be using them when I make up a quick hitch later this summer. Please keep us informed of your progress on each new project. I have a Lincoln Arc welder in the basement and will hopefully put it to good use this summer. Thanks again for the effort, great job /w3tcompact/icons/smile.gif
Action shot. This was a live Oak tree. This stuff was heavy. the pcs shown in the grapple are about 7 feet long each. There were three small loose piles, I scooped up the first, dumped it onto the second, etc, until I had them all. One fell out, but otherwise what you see was one load. Made short fun work of the tree trimming cleanup.
Dad's turn in the Lift, operating the chainsaw on a few limbs...
Discussing the "plan"...before I start the tractor and hoist him up.
/ Combo Base frame / material handle tine attachment #33
Great pics. I love action shots.
That grapple is impressive. I didn't expect to see it holding so much. Good job!
--Brad
/ Combo Base frame / material handle tine attachment #34
Jim, All I can do is echo what everyone else has said. Impressive.
_______________________________________
Take care, Jim
/ Combo Base frame / material handle tine attachment #35
Jim,
As others have said, your work is awesome! Wish I had the knowlefge and ability to tackle some projects like these.
About the photos, do you have fluorescent lights in your garage? If so (as I suspect), that and the daylight film are the combined culprits. Other than the the yellow being washed out, the photos are excellent - especially the outdoor shots.
Barry
/ Combo Base frame / material handle tine attachment #36
The cold rolled version will give a great strength advantage over the hot rolled.
"cold-rolled stronger" Thanks, I thought that was true, but forgot where I heard it. So far so good. Unless I do something stupid and put one tine under something still in the ground, its going to work.
/ Combo Base frame / material handle tine attachment #38
Re: Combo Base frame / material handle tine attach
A little late chiming in Jim but let me add my Kudos for such a terrific piece of work. You are my fabrication hero. Based on my years of experience with tractors I would estimate that the items portrayed in this thread would sell for about $12,000.00!!!
WOW! I was guessing at a retail value of around 2500, but I like your math better. If that's an offer, I accept. Thanks for the feedback...
