Column Alignment
/ Column Alignment #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Muhammad, an observation from the obsessive compulsive delegation /w3tcompact/icons/laugh.gif...the columns (Subject, Poster, Views, etc.) in the Kubota forums do not line up with all the other forums. This is with IE 5.5.
/ Column Alignment #2
Yeah, the "subject" cell is being stretched by <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=buykubota&Number=153486&page=0&view=collapsed&sb=5&o=0&fpart=1#Post153899>this thread</A>. /w3tcompact/icons/smile.gif
Once it scrolls off the first page, it will be the default width again.
Are you in flat or threaded mode?
/ Column Alignment
Flat.
/ Column Alignment #4
Oops... I meant, expanded or collapsed?
/ Column Alignment
Collapsed. Now the columns are all lined up OK.
/ Column Alignment #6
Well, if that one post was made bold, that would change things after it's marked as read. Bold = wider.
/ Column Alignment
Just to be sure we're referring to the same thing. {see attached}
/ Column Alignment #8
Well yes, I first thought you meant that because those are the only columns that get off sometimes... and it's really not because of anything. Kind of a glitch in how the tables get rendered... they're not all linked, but they should be the same based on the code.
Since they're dynamically generated, it's not like we can just change something in the Kubota table... so thankfully, they work as they should, most of the time. /w3tcompact/icons/smile.gif
/ Column Alignment
Thanks for checking and the explanation.
2023 KOMATSU PC490LC-11 EXCAVATOR (A65056)
2023 KOMATSU...
Assortment of John Deere Gator Parts (A64912)
Assortment of John...
2025 Swict 78in Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2829 (A65055)
2829 (A65055)
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
