Column Alignment
   / Column Alignment #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Muhammad, an observation from the obsessive compulsive delegation /w3tcompact/icons/laugh.gif...the columns (Subject, Poster, Views, etc.) in the Kubota forums do not line up with all the other forums. This is with IE 5.5.
   / Column Alignment #2
Yeah, the "subject" cell is being stretched by <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=buykubota&Number=153486&page=0&view=collapsed&sb=5&o=0&fpart=1#Post153899>this thread</A>. /w3tcompact/icons/smile.gif
Once it scrolls off the first page, it will be the default width again.
Are you in flat or threaded mode?
   / Column Alignment
Flat.
   / Column Alignment #4
Oops... I meant, expanded or collapsed?
   / Column Alignment
Collapsed. Now the columns are all lined up OK.
   / Column Alignment #6
Well, if that one post was made bold, that would change things after it's marked as read. Bold = wider.
   / Column Alignment
Just to be sure we're referring to the same thing. {see attached}
   / Column Alignment #8
Well yes, I first thought you meant that because those are the only columns that get off sometimes... and it's really not because of anything. Kind of a glitch in how the tables get rendered... they're not all linked, but they should be the same based on the code.
Since they're dynamically generated, it's not like we can just change something in the Kubota table... so thankfully, they work as they should, most of the time. /w3tcompact/icons/smile.gif
   / Column Alignment
Thanks for checking and the explanation.
UNUSED PAIR OF FUTURE 7" RUBBER TRACKS (A51248)
UNUSED PAIR OF...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
FRONTIER GM1060E LOT IDENTIFIER 233 (A53084)
FRONTIER GM1060E...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
