Color codes on pins
/ Color codes on pins #1
srjones
Platinum Member
Columbia County, Oregon, USA
Mahindra 2015HST & Mitsubish R1500
I'm starting to collect quite a few pins (5/8", 3/4", 7/8" & 1") for the different attachments I have and it always seems like I grab a size too small or big for what I need.
So, inspired by color coded socket sets, I was wondering, is there a color standard for the various sizes of pins?
For example...
/ Color codes on pins #2
man, I guess I'm pretty dumb - I just thought there were a cat 1, and a cat 2, and the rest of hte pins most of us will never use, like cat 0, cat 3...
/ Color codes on pins #3
WOW I must live in the dark ages--NEVER ever heard of color coding sockets.:rolleyes: If you cannot tell the difference at a glance I would suggest stamping the size on the end of the pin. There are not that many different sizes to contend with.
Now maybe it is a fashion statement--you need to color coordinate your pin sizes. Maybe Cat 1 should blue 7/8 and yellow 3/4 because purple and red would clash. :D If you really wanted to color code things follow the standard set by the sockets. I wonder if every maker of the sockets have agreed as to the color that 7/8 should be, maybe there is a standards war out there that I knew nothing about. :D
Did some quick research and discovered that not everybody agrees on the color that things should be. :cool: But usually 7/8 is dark grey or black and 3/4 is yellow--This does not seem to match the metric equivalents though.:confused: However I even found color coded wrenches!!:eek: The toolbox is now a fashion statement!!!
Mike
Think that's odd? Queen bees (honeybees) have a color code to identify what year they were born. It also helps identify the queen amongst the hundreds of bees on a frame.
Queen bee - Wikipedia, the free encyclopedia
The biggest challenge I have now is between 3/4" and 7/8". At 20 feet I can't tell the difference. Heck, at 8 feet I'd have a hard time. :)
Many other areas have color codes to identify the type/size of material in use, but I guess I'll need to come up with a system that works for me.
/ Color codes on pins #5
Mike
I agree Mike! What ever happened to working on stuff so much that you can tell the size of a bolt by feel only? Or can tell which wrench to get from looking at the bolt? Sigh - guess nobody has the time to invest in it.
Alright, alright, I see how it is... :)
But I know I'm not the only one uses color coding for contrast and organization. I think my wife tell you that fashion waaaay down on my priority list.
Have you ever tried to find a pair of green hand pruners the grass? What about bright orange?
BTW, my most sincere apologies to those that are color blind.
And you can do that in metric? heheehe....
That's why I keep a cheap plastic caliper in my shirt pocket...
/ Color codes on pins #8
now wait a minute - while coloring pins doesn't make sense, judging the age of your queen will help decide whether to use her eggs to make new queens. longevity is a nice trait, and it also helps you see if your queen has been superceded by the hive...(new queen has no dot) bunch of reasons to mark your queen, no reson tomark your pin
/ Color codes on pins #9
You bet! That's why I have both metric and english adjustable wrenches. I bought both 8" and 200 mm.
jb
/ Color codes on pins #10
I have a crome-plated left handed metric cresant wrench
/ Color codes on pins #11
I got out of pro-wrenching in the middle 60's and I'm waaay behind on this topic, do these Crescent wrenches work on zinc plated bolts, metric left handed thread only. If I have to now have one for each, I can see why the Snap-On truck is getting so big.:D
/ Color codes on pins #12
Actually because of where I live I can most of the time get the metric right. There are a lot of wrenches and sizes, but some are just much more common than others. 10, 13, 14, 17, 19 will cover most things. You work with them enough and you just get used to what the sizes look like. I do not know how else to explain it. :confused:
Besides that, I am not sure that it is not easier to just get used to the size than trying to remember the color for 19 mm. Now was that light or dark grey?
Mike
/ Color codes on pins #13
do you want the purple wrench with the pink stripe or the pink wrench with the purple stripe? No thanks I will stick with chrome,grease, ink and dirt colored wrenches. I can judge metrics pretty close 10,13 and 17 are used alot in my printing machines and a 13 is the same size as a 1/2" real wrench.
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2022 EZ-GO ELITE...
2013 Mercedes Benz GL 450 4 Matic AWD SUV (A64557)
2013 Mercedes Benz...
2019 FREIGHTLINER CASCADIA TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
