Cold Zinc Galvanizing
/ Cold Zinc Galvanizing #21
Soundguy, by band couplers, are you talking about using the type that have a compression ring, like Dresser fittings/couplers?
We used to use them out in the field in emergencies when we couldn't repair the threads, or had to torch cut the ends of the pipe.
more like this.
there are many other similar designs, some flat and uncorrugated, some flat and dimpled. etc.
http://www.menards.com/main/plumbin...-culvert/15-culvert-band-coupler/p-114437.htm
the dresser fittings you speak of we use when working on stuff like epoxy coated / steel water pipe.. etc. like 6" 8" etc.
/ Cold Zinc Galvanizing #22
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
golf cart (A56859)
golf cart (A56859)
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
