Cold Weather Starting
/ Cold Weather Starting #1
DLMaine01
Maine
Sold theKubota L2250DT and now have a Kubota M4900DT
We bought a 2250DT this November so this is our first winter with it. The manual says to energize the glow plugs for 30 seconds or so and then try and start. It never starts on the first try but always on the second or third try. Is this normal? The outside temp is between 10 and 20 degrees F when I start. Should I be doing something different? It is an older tractor and I am starting to do some work on it but will defer all but critical stuff until warmer weather.
/ Cold Weather Starting #2
30 seconds? Wow that is a long time. If an old tractor I would just check the glow plugs.
/ Cold Weather Starting #3
I energize mine for 15 seconds in zero weather and starts right up. As mentioned I'd replace the glow plugs and go from there.
/ Cold Weather Starting #4
30 seconds sounds like a long time...I have 3830 and live in Southern Maine, Started it 2 nights ago temp was zero and it fired up easy, glow plug light goes out after 5-10 seconds.....bob
/ Cold Weather Starting #5
I would test them before replacing them. Jsut get the proper ohms for each GP and go from there.
/ Cold Weather Starting #6
David
Welcome to TBN. /forums/images/graemlins/smile.gif
Your 2250DT is a mid 1980's tractor. If it is anything like my B7100 30 seconds may be on the short side of time in below freezing temperatures. Some glow plug was required even in 70 degree temperatures. Be sure battery is kept fully charged.
The best thing to do for your tractor would be to add a block heater. Your local <font color="orange"> Kubota</font> dealer should be able to get one for your model.
/ Cold Weather Starting #7
I agree but why not spend 30 minutes and test the plugs first? Is it free too. Then if they are ok, see what oil you are using. Also look at a coolant or block heater.
/ Cold Weather Starting #8
Adding some 2-Ethylhexylnitrate (2EHN) to boost the cetane value of your fuel up some would not hurt anything.
/ Cold Weather Starting #9
DLMaine01
I have an old B6000 that starts the same way. 30 seconds is not a long time for those old tractors. What I have found helps is to crank the engine for about 5 - 7 seconds before lighting off the GP's. This way when you try to start it, there will be fuel at the injectors. I think what happens is the fuel leaks down from the pump and by the time the fuel gets to the injectors the GP's cool down, but the second time you try it, fuel is there and ready to go.
That aside, it can't hurt to check the GP's, they ALL may not be good. And if you have the "old" style indicator, the small coil that lights up, it too can cause the GP's not to light if defective.
I am waiting for delivery of my new (to me) L3710, I have a new Block Heater ready to install. It does get cold up here!
Gary
Thanks To All....
For all the info and advice. I will probably try and replace the GP's because the tractor is indeed a 1985 and it is cheap insurance to do so. I had already contacted the Kubota dealer about a block heater and plan to install one, but was waiting for the weather to warm up a little more than the 3 degrees we had here today. I will try the pre-crank trick because the tractor always starts on the second or third try. I love the tractor and this seems like a great forum. Now if I can just talk the wife into that M4900.........
Thanks Again
Dave
/ Cold Weather Starting #11
Throw a tarp over the tractor and put a small electric heater under it till you get the block heater installed.
Egon
/ Cold Weather Starting #12
Dave...... glow plugs are like light bulbs.... they either work or they don't. Thirty seconds isn't a long time for a diesel of your vintage, and neither is the second or third trying to start before running, excessive considering the vintage of the tractor. I would say that it is normal from my experience. My 1963 Mercedes took 5 or 6 tries before it would fire up in cold weather, and my 1987 would start on the first try every time. Diesel engines have come a long way in the past 20 years and it isn't reasonable to put modern day starting standards on a engine that is of your engines vintage. The only thing that I would consider changing is the oil to a synthetic for better start up lubrication. If you had a dead glow plug, you would have a lot more problems starting that engine than 3 tries. There is a good chance that one defective glow plug would be enough to keep it from starting at all at the low temperatures you are experiencing. My BX22 took 3 tries today to start and that was with glowing the glow plugs each time for about 15 seconds. I consider this normal given the -4 degree temperature. When it is 40 degrees, it will start the first time every time with very little glowing necessary.
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
New 31X13.5-15 NHS tire on John Deere 8-lug grain drill/air seeder rim, Coal Valley, IL (A65640)
New 31X13.5-15 NHS...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
