Chains Cold weather starting a diesel
   / Cold weather starting a diesel
The tractor does have a thermostart with no wire attached. I had the impression that they were not very effective in real cold, but I'd be happy to be wrong about that. :)
   / Cold weather starting a diesel #42
OEM block heaters are a lot less than $75. TSC often gives the illusion of lower prices. Sometimes yes, sometimes not so much.
I never had very good luck with the Thermostart, Rick. I use 15W40 Chevron Delo 400 and even with a fully charged battery my 4610 was hard to start with the Thermostart unit at 20F. It seemed like it didn't turn over very fast. I attribute that to the cold oil viscosity requiring more torque. With a block heater it fires right up on the first rev. Maybe my starter is weak.
   / Cold weather starting a diesel #43
All things being up to snuff, a 4610 should roll right over and start at 20F without any starting aids. It wouldn't hurt to dump the 15W-40 and use 10W-30 in it. If it cranks slower without the block heater than with it, I'd be looking at oil viscosity. Everyone is in love with 15W-40 , but 10W-30 is a better choice till you get up to about 90F ambient.
   / Cold weather starting a diesel #44
how aboout plumbing in a brass peacock to the intake most hardware stores have them thanks
   / Cold weather starting a diesel #45
The INTERNATIONAL farm tractor[dont remember the model]that i plow with at work has a factory either canister for start up.Ijust push a button on the dashand it givesit a shot and away she goes.Ihad never seen this before and have run lots of old iron.
ALAN
   / Cold weather starting a diesel #46
My older JD855 compact has a soft plug block heater.
Would NOT be without one. Even with as much as -20 below all it takes is 1/2 hour plugged in to be toasty warm. But then it also only has 850 hours on it.
I'm sure there is some way to install a tank heater, or lower radiator hose heater.
Good luck
   / Cold weather starting a diesel #47
There is an off the shelf system made by Quick-Start. The system gives you a metered shot of ether so you don't over do it and has a thermostatic lock out so you can't use it once the engine has warmed up. Many of the trucks and loaders I worked on had these systems from the factory and they worked great. Easy to install and maintain. Here is a link to the company Products | Diesel Engine Ether Injection Systems
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2017 TROXEL 150...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
