Chains Cold weather starting a diesel
   / Cold weather starting a diesel #31
I just replied to another post about this. I had one. Unplugged it and plowed snow. Parked tractor and went to plug it back in but it was gone. It fell off while plowing and didn't find it till spring thaw. Others have said the thermal heat transfer is not that great. I use an inline lower hose heater which was the cheapest and fastest method to install for me.
I know this method works best, I just hate the thoughts of cutting into a new heater hose!!!
   / Cold weather starting a diesel #32
Won't use ether on anyone of my diesels other than the old detroit that has an ether cup on top of the bower. Ether, will bend rods, and unseat rings. in most modern diesel engines. A hair hairdryer can preheat can heat the intake, to get most diesels going.
   / Cold weather starting a diesel #33
My newly acquired diesel tractor has no cold weather starting aids. No pre-heater, no block heater. With my other tractors I spray ether directly into the air intake, but on this one the intake is buried up under the cowl. I've been spraying through the grille, but it doesn't seem to be very effective. Has anyone done some kind of home grown mod to allow ether to be sprayed directly into the intake stream? The manifold and rubber hose from the air cleaner is somewhat accessible, is there some slick way to install some kind of port for spraying ether in?
I'd strongly recommend a block heater. Two hours on and the tractor will start on the first roll. It makes it easy on the engine and they are relatively cheap(~$30 for your size tractor). All you need is access to electricity.
If there is a tapping in the intake manifold, you might be able to install a Thermostart unit. It uses fuel and a heated grid to preheat the intake air. I have one on my Ford 4610 but it's only good down to around 20F.
I used a torpedo heater to blow warm air under and around the engine block to start before I got a block heater and that works also. I tried a blow drier and it didn't work for me. It might work on a smaller engine than 201 cu in block.
I hooked my block heater to a timer that goes on two hours before I feed. After disconnecting the heater it starts on the first roll and I'm off to feed.
   / Cold weather starting a diesel #34
I'd strongly recommend block heater. Two hours on and the tractor will start on the first roll.
This is the best advice, I do the same, two hours before when cold and engine starts instantly.:D:D
DevilDog
   / Cold weather starting a diesel #35
I would never ever put that stuff in my tractor use a block heater .when I was shop forman at a IH dealership we put a new engine in a truck and the guy went to start in on a cold day just to see if it would start so he give it a shot and bent the rods and cracked some pistons then he called to tell me it wound not start so we went and picked it up to find out he sprayed it bang another new engine I think he learned his lesson lots of dollars wasted .no warrenty .
   / Cold weather starting a diesel #36
Remember, the newer machines are very different from the old timers. Anyone still driving a car with a hand choke?
Granddad started his tractor by advancing the spark, and then using the hand crank. And HIS daddy got the equipment going with a bucket of oats and a lap of hay!
More likely he retarded the the spark so he wouldn't break an arm. Too much advance and that sucker will rip your hand off!
   / Cold weather starting a diesel #37
If you have a TSC store around there you might inquire about a block heater. For around $75 and an hours labor, your cold-start problems could be over. With a block heater installed, that little block will heat up enough in 30 minutes at zero degrees to start easy.
OEM block heaters are a lot less than $75. TSC often gives the illusion of lower prices. Sometimes yes, sometimes not so much.
I'd like to install a block heater eventually, I have one in a freeze plug hole behind the starter on my 2600. That seems to be a good way to go, but unfortunately on my 420 the loader frame makes installing one quite a project.
   / Cold weather starting a diesel #39
The truth of the matter is that if the starter is a good starter, and the battery is good and strong, with very clean fittings, and it can vigorously turn the engine it`l start....Our very old deere , for years didn`t have a good starter (although it sounded good) and I gave just a very little ether and it cranked right up...When I got the entire wiring harness new battery and starter, it would catch very quickly unless it was very cold...I thought it possibly had become addicted to ether, but `no` just needed to turn over vigorously..Tony
   / Cold weather starting a diesel #40
A working thermostart unit coupled with a little patience can be a great help. However a working thermostart and use of ether can be a disaster. If you have fuel available at the thermostart unit and power is supplied when the key is in the preheat and crank position, replacing the unit is easy and inexpensive and can be very helpful starting the tractor down to the single digits if starter, cables, battery and engine compressuion are up to snuff. It is good practice to disconnect the electrical wire from any type of manifold heater (thermostart or grid) when ether is used.
2016 Ford Expedition SUV (A55853)
2016 Ford...
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
TRI PLEX PUMP (A55745)
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2005 Ford F-150 Ext. Cab Pickup Truck (A55852)
2005 Ford F-150...
