/ Cold weather start, with glow plugs and block heater. Why does my tractor not start at minus 20 C?
			#31
			Most HST fluid is 30w or less, so it doesn't get quite that thick unless you are going below -20F. But yeah, it's certainly a drag on the engine.When it's that cold, even with a block heater the crankshaft and rotating groups for the hydrostatic system is facing huge resistance from honey-thick fluids in the journals and passages.
I do use a small silicone pad heater on the bottom of the differential. It keeps the fluid from being affected by the cold, and reduces the published warm up times.
