Cold weather Mt573
/ Cold weather Mt573 #1
4uu
Mt573 LS
I've owned this LS MT573 over 2yrs 410hrs. It's definitely not a cold weather tractor. Have a block heater and it's not enough at 20degrees I have to use a 20lb lp heater to warm the oil pan. The cab doesn't warm up enough to keep the ice off windshield(snow blowing). I don't recommend this tractor if you need it to move snow. The crank case breather hoses freeze and builds pressure in the crank case it and blows the oil fill cap off.
/ Cold weather Mt573 #2
Like the old days would blocking the radiator help any?
/ Cold weather Mt573 #3
Is the MT573 a power shuttle?
If so a para-synthetic hytran oil in the transmission/hydraulic reservoir may help as well as a synthetic motor oil.
Have you replaced the thermostat?
I also cover the radiator on the tractors in the winter.
/ Cold weather Mt573 #4
Is the block heater working properly??
I would suspect a kinked heater hose or maybe a partially closed heater hose valve somewhere maybe a faulty temp controler. Cab should get warmer than that. The cab heater in the cab of my XR3140Hwill run me out of the cab when plowing. I would suspect an engine running that cold would set off emissions codes at minimum, not too rule out a failing thermostat though.
I run a semi-synthetic engine oil and a high grade tractor/hydraulic fluid chevron THF 1000 in the 3140H for trans/hyd fliud and no block heater. When I had to plow on a single didgit days, wich I try to avoid plowing on, the LS has always started when the heat coil light turns off.
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
2023 Bobcat T64 (A64126)
2023 Bobcat T64...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
