Cold TC45D
/ Cold TC45D #21
New Holland has told dealers to cure the cold running problem on the class III tractor by installing a valve as yours did. The problem is that the drain hose acts as a bypass (not designed to) for the thermostat and allows the antifreeze to start circulating with out the engine warming up.
/ Cold TC45D #22
Well I have now bought two B&S Fuel Shutoff valves (PN 493961). Both have leaked. I finally just plugged both hoses and the tractor warms up nice to normal temp. I maybe wrong but I swear this tractor has a lot more power at the correct temp.
/ Cold TC45D #23
I have the cold engine problem in my new TC-45 with about 30 hours and have arranged for the dealer to make the fix. My question is this -- does anybody know how running cold for the first 30 hours affects the normal break-in process? Is there anything I should do differently during break-in?
/ Cold TC45D #24
<font color=blue>...anybody know how running cold for the first 30 hours affects the normal break-in process?...</font color=blue>
Now... you'll have a beautiful cold-blooded tractor... /w3tcompact/icons/wink.gif
/ Cold TC45D #25
My brand new TC35D...
I was reading this thread, and decided to check out my TC35D, which was built on 09/19/01 - 09/21/01, and it does NOT have a shut-off in the line. FYI to all Class III boomers buyers out there - it looks like this is STILL not being incorporated at the factory. Does anyone know of a good place to get the B&S in-line valve? And a part number?
Thanks!
There are old pilots, and there are bold pilots, but there are very, very few old bold pilots. And they get scarcer every day.
/ Cold TC45D #26
Re: My brand new TC35D...
The B&S valve that I have seen is a little too small for the 5/16" hose on the coolant line, but I guess some have got it to work. Also, the valve is plastic, not suitalbe for pressure and I think with continue use may fail. Instead I used a small 1/4" brass ball valve with 1/4" threaded x 5/16" brass barbed fittings. It's a little larger but there's no chance of failure as it's suitable for the temperature, pressure and coolant chemicals. Bought both from McMaster-Carr Online.
/ Cold TC45D
You don't want to use the B&S valve. Make sure you find a valve rated for the temp & pressure. The plastic B&S valve the dealer installed in mine failed... Not a good thing & now they won't stand behind their solution. /w3tcompact/icons/mad.gif
/ Cold TC45D #28
Thanks, guys - looks like this weekend's project!
/ Cold TC45D #29
I went the same way as djradz did and just fixed my TC40D with a ball valve and barb fittings bought from McMaster-carr online. It seems to work good. the parts I used were:4912 k47 ball valve and a pack of 5346 k16 hose barbs. Total cost with shipping, 13.64 plus the clamps I had on hand already.
/ Cold TC45D #30
Does anyone know if the Plain TC45 models have the too cool problem? The plain janes don't have a temp gauge. Mine has a drain valve where you guys installed the ball valve. I'm concerned because the owners manual says running too cool will cause engine damage.
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Honda UTV (A56859)
Honda UTV (A56859)
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
