Cold starting
/ Cold starting #1
LouNY
Super Star Member
Greenwich, NY
Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Evening all;
My Branson 8050 does not like to start when it's cold out. Last winter it wouldn't start a few times when I needed it, I would have to put a tarp on it like a tent over the hood and run the salamander heater for an hour to get it to start.
My dealer had installed a lower radiator heater in it when I bought it, it does not seem to be effective, the hoses get hot but there does not appear to be any heat getting into the block. This year I switched to Rotella T6 5w-40 and cen-pe-co oil in the tranny so far in the teens it has started. Does anyone know if a block heater can be fitted to this engine and if so which frost plug and what size?
Thanks
Lou
/ Cold starting #2
As you have investigated and proven , the heated coolant is not moving via convection through the engine . There has to be a tall vertical column of light warm water rising and a tall column of cold heavy coolant pushing the warm light water.
/ Cold starting #4
Simply
A lower radiator hose heater and the closed thermostat have NOTHING in common
note the schematic
Water cooled engine - ThingLink
It is important that there is sufficient vertical rise when locating the heater.
I have a lower radiator hose heater on the mitsubishi K4f and it works wonderfully.
/ Cold starting #5
If you can get the points of a dial caliper into the groove where a freeze plug sets, you can order the appropriate size block heater. I think they are made all the way down to 18mm.
Agreed with the others - a lower radiator hose heater works beautifully, but ONLY if installed in the vertical column of the lower hose. If its in the horizontal portion, it was installed improperly.
Don't forget the orange heater pads that can be glued on the bottom of the oil pan. I used to buy mine from Summit or Jeg's. These work awesome for getting the oil loosened up when it's that cold outside! I hate starting engines with unheated oil when it creeps down into the teens...
Amazon.com: Kat's 2415 15 Watt 4"x 5" Universal Hot Pad Heater: Automotive
/ Cold starting #7
Some inline heaters may have to be mounted in a vertical hose. It should also have direction of flow on it.
That said I have successfully used an inline heater on a horizontal hose on a Kubota B 7100. It worked very well. The installation required proper flow direction and the unit itself required proper verticle installation on a horizontal run.
/ Cold starting #8
I installed a block heater on my 4520r (actually just plugged it in this morning). It is located in the left side of the block about mid engine. There is a threaded plug removed by a 1/2" square drive socket extension. Unscrew the plug out and screw the heater in. I purchased it from NAPA but I don't recall the #.
/ Cold starting #9
I don't believe you can install a block heater on an 8050.
/ Cold starting #11
Intake heater, no glow plugs. That seems to be the norm now a days. Seems everything is going intake heat. It works good.
/ Cold starting #12
Darn, I was going to suggest adding one from an older Dodge Cummins engine!
Pointing his salamander heater at the intake manifold (not too close!!!) may help get it going quicker than doing the whole "tent" idea.
/ Cold starting #14
My old Ford 2000D has 2 heating elements in the intake manifold, manually switch operated. Both Branson Cummins licensed engines (B3.3 NA and A1100NA) use glow plugs even though the 3.3 is direct injected and the 1100 is swirl chamber ignited.
/ Cold starting #15
Open combustion chamber diesels have to use intake manifold heaters as there is no place for glow plugs in the combustion chamber.
/ Cold starting
Afternoon all;
Just a quick update on my 8050 starting; The Rotella T6 5W-40 synthetic oil in the engine and cen-pe-co oil in the the hydraulic/trans and she starts very well,
I did get a block heater installed in her, on the oil filter side of the engine just about center there is a 1" npt plug with a recessed 1/2" square drive, I removed that plug and installed a 600 watt 1" npt heater which fit good in the block, the only problem was that the oil cooler water line fitting is extremely close to that same plug and the hex'es would not clear I ended up putting a close nipple 3/8 npt and coupling in then the oil heater fitting to get the hex's to clear, works great she will start in sub zero temps now, the manifold heat sensor will try and shut off to soon so I will cycle it 2-3 times before going for a start.
Lou
/ Cold starting #17
Glad you got her fixed. Nothing like having a tool that works.
JOHN DEERE 4640 TRACTOR (A62130)
JOHN DEERE 4640...
BUNDLE OF APRROX (45) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
2024 SCAG SCZ61V Cheetah 60in Zero Turn Mower (A61567)
2024 SCAG SCZ61V...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
