Midniteoyl
Super Member
- Joined
- May 20, 2013
- Messages
- 5,237
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Dont know if you have one, but they make stainless chimney liners just for this use - inserts in a large fireplace. The large open flues just dont work well with the inserts..
As for the draft inducers (the power option mentioned), I made my own once.. worked great until I found that getting a draft wasnt the only problem this 'new' install had... After the fire, I put in a proper Zero Clearance wood stove and 7" Excel insulated stainless pipe..
For starting, I use two pieces of wood with a firestarter in the middle and a another wood piece as a cap. Air is the outside air open full and door cracked about an inch. Once the starter burns out, the top piece is going fairly good so I drop it down in between the other two, place 2-3 more on top and close the door leaving the intake wide open. After about another 10-15 mins, I close the intake about 1/2 way and wait for the coals to form.
