Cold Rolled or Hot Rolled
   / Cold Rolled or Hot Rolled #1
jaydee325
Veteran Member
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
I want some hydraulic cylinder safety props. 2 - 2" X 16" pieces of angle should do the trick. What would be better to use, hot rolled or cold rolled?
   / Cold Rolled or Hot Rolled #3
I'm in the same boat and I was thinking U channel for contact on 3 sides of the prop.
For that job it doesn't matter.
What does matter is how thick the angle is and you're leaving that info out.
How thick should I go?
   / Cold Rolled or Hot Rolled #6
`Like Yogi says, a channel would be better to assure it doesn't pop out. You could add some tabs to a angle, to make that.
   / Cold Rolled or Hot Rolled #7
That's a compression load, very easy for a 3/16-1/4" angle. Maybe 2x2, 3x3 might provide a better "footprint".
   / Cold Rolled or Hot Rolled #8
You can even use aluminum angle or channel, less chance or marring the rod. I've never seen "cold rolled" angle though.
   / Cold Rolled or Hot Rolled #9
Good point on marking up the rod. I use 2x2x3/16 steel. A couple layers of duct tape would go a long way to prevent marks.
   / Cold Rolled or Hot Rolled #10
I always figured this
would work better than this
WAY more contact with the piston housing.
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
Case 830 Tractor (A50514)
Case 830 Tractor...
