Oil & Fuel Cold Diesel Engine Again
   / Cold Diesel Engine Again #11
Try using WD40, CRC 556, etc. instead. Volatile enough to enhance the combustion process and adds lubricant.
   / Cold Diesel Engine Again #12
Heat will do wonders to make starting easier! /forums/images/graemlins/grin.gif
Otherwise there is no simple solution.
Egon /forums/images/graemlins/grin.gif
   / Cold Diesel Engine Again #13
Absolutely. Figuring out where to get the heat from can be problematic though. I just am NOT a believer in ether as a starting aid. I'm not a big believer in starting a charcoal fire under the engine or fuel tank either, but we do what we have to, to get-r-done.
   / Cold Diesel Engine Again #15
i have a 1961 fordson dexta with a perkins deisel engine. it does not like starting fluid. don't want to crack pistons or rings. it doesn't like it. suggestions on cold weather starts?
   / Cold Diesel Engine Again #16
There is a starter upgrade/different starter that can be used on the dexta. It'll turn the engine faster. Found this out from my neighbor/tractor mechanic. When I see him again I'll ask what he uses.
Had an uncle that had a dexta diesel. We spent lots of time pulling him and the tractor on winter mornings trying to get it started. I know what you mean about cold starting one of those. Good tractors in warm weather though.
   / Cold Diesel Engine Again #17
"I would like to avoid heating contraptions."
I don't know what you consider a heating contraption, or where you store your tractor, but I store mine in a barn with no power and if I had the problem, I would throw a cheap tarp over it and a kerosene heater under it and let it heat for a few minutes before starting.
   / Cold Diesel Engine Again #18
fordson parked in a unheated garage without perment power... sometimes parked in bank barn 1/4 mile away... don't want to burn it down!
   / Cold Diesel Engine Again #19
Try some spray silicone into the air intake. It's safer than ether and might generate enough heat to warm it up faster. WD 40 can also be used.
   / Cold Diesel Engine Again #20
Don't either that Perkins. You will crak a ring for sure. You are right, they don't like either.
A couple of suggestions that work:
A rag over the air intake that has a little gasoline in it. Gasoline is easier than either on your rings.
If you can, get a power inverter for your car that will run a blow dryer. Place the blow dryer in the air intake with it on hot air and crank it (the tractor engine). All it takes is a little shot of warm air in the intake to get it going.
Used to use that trick with my old IH-6.9 with shot glow plugs.
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
Pallet of Vehicle Seats (A54816)
Pallet of Vehicle...
