Cockshutt 20 Distributor
/ Cockshutt 20 Distributor #2
Ok, I've contacted a few friends, and this is what we have come up with colectively:
Here are some Neihoff #s for Cockshutt 20 with Continental F 124 or F 140 with Dist No. IAD-6004-1C. Points # AL 5-23 HV or AL 5-23M,condenser # AL34, rotor #AL 81, and cap # AL 73.
Is the distributor a Prestolite or Autolite with an id tag on it? (Or other make with stamped numbers?)
If you know the distributor make and have some numbers, I can look it up in the Standard Ignition Ag and Industrial cross reference, and get you Standard #'s that many auto supplies can get overnight, or you can cross those numbers at NAPA, or wherever
May also want to contact Phil Heisey in PA...he's usually on the cockshutt board or the Lesser Known Classics board and carries a lot of parts for the Co-Op/Cockshutt tractors.
Get back with us.
Soundguy
Soundguy,
...see I should have checked with you first! I am going to investigate the numbers today. I did replace the original autolite. And NO I did not toss it and NO I did not toss the box the new one came in. But between the two buildings anf the 'umpteen' hiding place I be **** if I could fine the stuff the other night. I did fine the old plugs and wires but no cap etc.
Oh, and I did find alot of other things too!
Believe me it is organized...on a good day!
Many thanks again...will let you know...
Have a good one.
lloyd
Napa came through.
Sound Guy,
Napa came through with the part - AL69 rotor button.
Tight fit...but fire up in cold no problem.
Many thanks again.
They had a good cross reference catalogue there for cockshutt stuff.
The guy even visited the plant in Chigago were the continental engines were made.
regards,
Lloyd
Have a safe and Merry X-mas.
/ Cockshutt 20 Distributor #5
Hi...My brother and I are looking for a repacement gear that drives the oil pump and distributor on a model 20 cocksutt.
Any information on aquring one will be greatly appricated.
