Coated Steel Pipe - Value?
   / Coated Steel Pipe - Value? #1
yeehaw
Bronze Member
I've got some coated steel pipe (think the ole 2 3/8) that appears to be brand new - has the greyish - rubber feeling coating on the outside and a lining on the inside. they are 10 ft sticks... any idea of how much they are worth? I cant find anything about them on the internet, everything I find is about uncoated stuff.
I was told i could weld it by just grinding the outside coating off---but I may be better off selling this and getting some other pipe (got this "years ago" for a steal)
thx
   / Coated Steel Pipe - Value? #2
I bet you got coated conduit
Admin
went to a scrap yard - almost no one knew what it was--- one guy said some utility companies use it instead of stainless b/c it wont rust--- but didnt know the value--- just coated steel...
   / Coated Steel Pipe - Value? #4
or, perhaps because it is a much cheaper rust resistant option than stainless steel.
correct - I worded that wrong.... 8~)..
also supposedly "non conductive and noncorrosive" so maybe some sort of conduit but we'll see...but heavy as all get out
turns out it is made by Thomas and Betts and says Ocla on it....may be 15-20 years old - but looks brand new.
   / Coated Steel Pipe - Value? #7
If possible check out the coatings for fume toxicity prior to welding.:)
   / Coated Steel Pipe - Value? #8
Sounds like PVC coated galvanized rigid conduit.
Found your Ocal listing:
Menu
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2017 Chevrolet Sonic Sedan (A55758)
2017 Chevrolet...
2023 KOMATSU PC55MR-5 EXCAVATOR (A52705)
2023 KOMATSU...
2019 MultiQuip Mayco C-30HDGA 3in Towable Concrete Pump w/ Hoses (A52377)
2019 MultiQuip...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
Filing Cabinets (A52378)
Filing Cabinets...
