Co-worker hurt while using tractor.
/ Co-worker hurt while using tractor. #11
I just bought a post hole digger, it works great. I WILL NEVER get off this tractor with an implement engaged. It just plain is not safe.
My 2 cents worth I guess.
/ Co-worker hurt while using tractor. #12
Miklos,
I am not sure that it is a good assumption that the tractor driven post hole diggers are necessarily dangerous, nor should it be assumed that a bobcat driven one is necessarily safe. Digging by hand might be safer, but I think you might not get alot done. I think that the real lesson here is to only operate the tractor or its implements from the seat of the tractor. There have been a few other discussions here about some close calls with tipping the tractor over onto yourself by operating the loader from the ground. I think that, although there are risks with everything, the best advise is to stay in the darn seat, and if you must get down to check something out or to chain something up, etc. shut down the PTO, put on the brake, put the FNR lever in Park, whatever applies to your tractor to make it not go anywhere, and have nothing spinning.
/ Co-worker hurt while using tractor. #13
<font color=blue>"Digging by hand might be safer,..."</font color=blue>
Ron,
Although I agree with everything else you said in your reply, I would slightly disagree with the digging by hand might be safer statement. Notice I said slightly disagree. I have a good friend who has a 1/2 of a right foot that was the result of an off line manually operated post hole digger! /w3tcompact/icons/sad.gif
I think what this tells us is exactly what has already been mentioned. It doesn't really matter what a person is doing. Danger lurks around the corner with any job/project/activity IF we, as the operator/laborer/participant fail to pay attention and understand the risks that are present in the job/project/activity.
/ Co-worker hurt while using tractor. #14
RF33
I should have stated in my previous post that one of the reasons for not ever purchasing one is the ground I have to dig in. There is about 6~12" of top soil, then hard clay with round river rock that range in size from 3 to 8" around. Once you get thru the clay/rock mix at about 24~30" depth, then you hit hardpan clay that is just one stage back from rock. Most any auger can easily get thru the top soil. Once you hit the rocks, you quickly wind up with a stuck auger if you can not reverse your auger. Once you get thru to the hard pan, without serious down pressure, you can only scratch the surface. Without reversible pto and down pressure a tractor with an auger is useless on MY property. Been there, tried that and it doesn't work.
With a Bobcat mounted auger I have never had to get out of the seat when drilling holes. The main reason is the ability to reverse the auger when it gets jammed in the rocks. For this simple reason, it is much safer for ME to use on MY property. When I drilled the 24" diameter holes for my pole barn with a Bobcat mounted auger, some holes took almost 2 hours per hole.
In the right type of soil and ground condidtions, a tractor mounted auger is perfectly safe as long as the operator remains seated on the tractor when the PTO is engaged. All helpers must stay a safe distance away when the PTO is engaged.
Like most everthing else in life, there are many different circumstances of use that can turn an implement from a safe, effective tool, to a useless health hazard. Get the right tool for the job!
Be safe out there.....
/ Co-worker hurt while using tractor. #15
Wow, Sorry to hear about anyone getting hurt - particularly that bad. Best wishes to him and his family. Every once in a while I cruise through this section of TBN to get a dose of reality and bring my tractor cockiness back down to earth. It doesn't pay to be complacent.
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2025 Mini Excavator Bucket Attachment (A59228)
2025 Mini...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
DEUTZ MARATHON...
Caterpillar 24in Digging Tooth Bucket Excavator Attachment (A59228)
Caterpillar 24in...
