CNC cost
/ CNC cost #11
I use a pretty simple formula.
1. The drawing software that I use tells me the linear inches cut on each part.
The shop I bought most of my CNC-cut steel from had a formula based
on the volume and shape of the piece you wanted cut. I first found them
on eBay, but they are no longer there.
I found it very reasonable to have my 1/2" plate cut and shipped from
LA to where I am in N CA. I tried to get one of the local shops I deal
with do it, but they were way way more money, even without shipping.
It seems to me that if a shop has idle time on an expensive CNC table, and
a customer submits a DXF file, they should be very reasonable. It was
so inexpensive, I can't begin to justify the cost of a hobbiest-type CNC
plasma setup (though I already have the plasma cutter).
/ CNC cost #13
As an example for pricing using my formula:
Lets say you needed a 12" x 12" piece of 3/8" steel with 4, 1/2" diameter holes. I would cut this part on one of my cnc machines at 65 amps with my plasma system......and the part would sell for $29.68, and could ship anywhere in the country (flat rate, USPS) for around $10.
That should be a relatively comparable price for plasma cut steel parts. You can expect 1/2" bolts to fit well through the holes, and tolerances on the part would be within about .020".
Jim Colt
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
John Deere 4510 (A53317)
John Deere 4510...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
