Cluthc/Transmission question
   / Cluthc/Transmission question #1
PoconoMan
Uniondale, PA
Yanmar 276D
I've been an automobile mechanic for the last 20 years and recently bought my first compact tractor. It's a Yanmar 276D and honestly, I don't know too much about them. My question is, when using the tractor, in any gear, I release the clutch pedal from a dead stop and the tractor just sits there for about 3 to 5 seconds then it engages as if it were an automatic transmission that was idling too low. But this tractor has what I assume to be a conventional dry clutch which in an auto application, should engage as the pedal is released. I was moving snow and when I tested the clutch against a snow pile, it will stall the engine so I would think its not slipping. It has a "power shift" transmission, whatever that is as well.
Sorry to be long winded!
Thanks!
Sean
   / Cluthc/Transmission question #2
You need to clean your pickup screen and replace the hydraulic fluid with a JD303 type fluid. The symptoms are not uncommon for your tractor.
Bruce
Thanks Bruce, I really appreciate your help. I was a little worried as I bought it "unseen undriven" and thought I had made a mistake.
On another note, I see that you have a website for Yanmar's. I'm going to repaint this tractor and was wondering if you have, can get, or know where I can get a complete decal package for it.
Again, thanks.
Sean
   / Cluthc/Transmission question #4
hello Sean, welcome to tbn. yes, you can get decals for yanmar. while there maybe other sources, you may want to start looking at hoyetractor for these types of things... they're at www.hoyetractor.com.
good luck -arthr
Thanks for the welcome as well as the link for the decals arthr, I appreciate your help.
Bruce; I did as you recommended today and you were right, tractor now engages tight as a drum. Many thanks. There was allot of what appreared to be blue paint chips and flakes in the screen. I can't imagine that they paint the inside of the cases,..do they?
Thanks again,
Sean
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52141)
2005 INTERNATIONAL...
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
TEST BID LOT (A50774)
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
