clutch zetor 6045
/ clutch zetor 6045 #1
NEVILLE MCGILVRAY
KILLABAKH N.S.W.
ZETOR 6045
Hi I have a clutch problem on a zetor 6045 . You push the clutch petal doesn't disengage the clutch, everything outside looks good , can you adjust this clutch inside without splitting the tractor.or any info will be appriciated.
Regards
Neville :confused:
/ clutch zetor 6045 #2
You will get better information at the zetor forum on another site just for zetors. search for zetor tractor forum I dont have the site address handy
/ clutch zetor 6045 #4
I suppose it is hydraulic clutch all about. They are not the best sollution Zetor ever had.
I have it on one of my tractors. Do you have any leaks on your cillinders? You can adjust it on the bolts on the end of rod wich is just uder cabin, I can take a picture if you havent found a sollution.
Hoppe problem is allready solved!
