Clutch/Trans ??
/ Clutch/Trans ?? #1
JLoaf
White Co., ARKANSAS
Kubota L3830 DT & B2710
I have an L3830 w/ std tranny. Lately while tilling, I'll push in the clutch and the tractor will actually accelerate - the engine does not speed up though. When I let off the clutsc it resumes normal speed.
It does not happen every time but I need to fix whatever is causing that.
It only happens when the pto is engaged.
A friend suggested adjusting the clutch? Does that sound right?
I appreciate comments on this.
/ Clutch/Trans ?? #2
When you push in the clutch, the tiller pushes you forward. Raise the tiller out of the ground and then push in the clutch and see what happens. I think that you will come to a stop unless you are tilling down a steep hill.
ron
/ Clutch/Trans ??
I think you are correct!
Sometimes I forget to think :(
Thanks.
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
3pt 5-Shank Subsoiler (A64127)
3pt 5-Shank...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
