clutch stuck, Ford 1920
   / clutch stuck, Ford 1920 #21
From the owner's manual the freeplay on the clutch is 3/4-1 3/16 inches. The levers are as follows: curved T by your right heel is the differential lock, the lever to engage the 4wd is by your right leg (looks like an upside down L), the large lever nearest the right fender is the 3PH lift. Once you get your clutch free make sure you block the pedal when it is parked to prevent it from repeating. Bill C
   / clutch stuck, Ford 1920 #22
Thanks Bill! I looked at the diagrams by the levers and couldn't figure out what they were. I figured the one on the floor was the diff lock because that's where it was on the Deere. Never owned a 4WD so I wasn't really sure if that was the lever or not. Thanks for clearing it up!
   / clutch stuck, Ford 1920 #23
I have this problem with a late 70's 1910. I can put the tractor into any gear sequence and it will not budge an inch. No problems engaging the PTO and no grinding when going through the gears. Does thisd sound to you folks as the same problem that can be remedied by propping cluch pedal down? Thanks!
   / clutch stuck, Ford 1920 #24
are you saying you have no driveline connection to the wheels when in gear and clutch not pressed?
   / clutch stuck, Ford 1920 #25
If I understand you correctly - yes. When the tractor is running, I can depress the clutch, put the tractor in any gear sequence, release the clutch and no movement.
I cut a length of 2x4 and prop-depressed the clutch per other folks contributive suggestions. I don't know if that is the fix or not. It has sat for about 3-4 months without use.
   / clutch stuck, Ford 1920 #26
you have the reverse of many peopl's issue. ie.. their clutch will not release.
yours sounds like possible a sheard clutch hub.
pto work in neutral?
in gears when not moving?
   / clutch stuck, Ford 1920 #27
ps.. blocking the clutch in a situation like yours won't help.
   / clutch stuck, Ford 1920 #28
i would have to agree either the clutch face stripped off or a sheard clutch hub
   / clutch stuck, Ford 1920 #29
also check clutch petal free play if pedal is adjusted to tight it will make the clutch slip
   / clutch stuck, Ford 1920 #30
and if it's neither of those.. could be sheared rivits or bolts on ring gear, or broke pinion / coupling.. broke rear axle etc..
but I'd be looking at clutch 'area' first
soundguy
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
2013 PETERBILT 388 (A52472)
2013 PETERBILT 388...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
