clutch stuck, Ford 1920
/ clutch stuck, Ford 1920 #21
From the owner's manual the freeplay on the clutch is 3/4-1 3/16 inches. The levers are as follows: curved T by your right heel is the differential lock, the lever to engage the 4wd is by your right leg (looks like an upside down L), the large lever nearest the right fender is the 3PH lift. Once you get your clutch free make sure you block the pedal when it is parked to prevent it from repeating. Bill C
/ clutch stuck, Ford 1920 #22
Thanks Bill! I looked at the diagrams by the levers and couldn't figure out what they were. I figured the one on the floor was the diff lock because that's where it was on the Deere. Never owned a 4WD so I wasn't really sure if that was the lever or not. Thanks for clearing it up!
/ clutch stuck, Ford 1920 #23
I have this problem with a late 70's 1910. I can put the tractor into any gear sequence and it will not budge an inch. No problems engaging the PTO and no grinding when going through the gears. Does thisd sound to you folks as the same problem that can be remedied by propping cluch pedal down? Thanks!
/ clutch stuck, Ford 1920 #24
are you saying you have no driveline connection to the wheels when in gear and clutch not pressed?
/ clutch stuck, Ford 1920 #25
If I understand you correctly - yes. When the tractor is running, I can depress the clutch, put the tractor in any gear sequence, release the clutch and no movement.
I cut a length of 2x4 and prop-depressed the clutch per other folks contributive suggestions. I don't know if that is the fix or not. It has sat for about 3-4 months without use.
/ clutch stuck, Ford 1920 #26
you have the reverse of many peopl's issue. ie.. their clutch will not release.
yours sounds like possible a sheard clutch hub.
pto work in neutral?
in gears when not moving?
/ clutch stuck, Ford 1920 #27
ps.. blocking the clutch in a situation like yours won't help.
/ clutch stuck, Ford 1920 #28
i would have to agree either the clutch face stripped off or a sheard clutch hub
/ clutch stuck, Ford 1920 #29
also check clutch petal free play if pedal is adjusted to tight it will make the clutch slip
/ clutch stuck, Ford 1920 #30
and if it's neither of those.. could be sheared rivits or bolts on ring gear, or broke pinion / coupling.. broke rear axle etc..
but I'd be looking at clutch 'area' first
soundguy
/ clutch stuck, Ford 1920 #31
soundguy
and hoping thats what is wrong
/ clutch stuck, Ford 1920 #32
Thanks gentlemen for your replies. My father in law had problems with the clutch the last time he was operating it and it flipped on him according to his son who noted it was a clutch problem that made it buck and flip. I had it towed to my place and I presume will have quite the time figuring it out. Again, thanks. NPNH
/ clutch stuck, Ford 1920 #33
start with the pto..
/ clutch stuck, Ford 1920 #34
My sugestion is to go ahead and block the clutch and walk away for a few days.. then come back and check.. many times they pop loose on their own.. if not, go ahead and get it in gear and start it... not super easy.. but with a lil jumper wire you can do so from the op seat.. keep the clutch blocked and drive it around in figure 8's stomping on the brakes.
if that don't do it, you can also use your lil jumper wire to set there and bump the starter over with her in high gear and the clutch blocked and try to pop her loose.
lastly, put a pto load on her like a mower and start her with pto engaged a couple times.
one or more of those have always worked for me in the past... have yet had to split one from a stuck clutch.. though do realize that in some extreme cases.. you don't have much choice.
have enen pulled starters so I could get a poker in there to tap around on the clutch too..
post back.
soundguy
This is very sound advice to anyone with a "frozen" clutch.
/ clutch stuck, Ford 1920 #35
I am having the same issue with my '97 1920. Happened once last year and It fixed itself. Now this year, tractor sat for 2-3 weeks in the humidity and now its doing it again. I have been keeping it in mid gears, slamming the breaks until she dies and it does not seem to give. I like the idea of dragging a box blade to help, may give that a try. Otherwise, Im to the point of splitting the tractor as I need it for the winter months.....
/ clutch stuck, Ford 1920 #36
I wouldn't give up just yet. For only a few weeks you should be able to be]reak this free. A pull start in first gear is one way to do it. If you haven't already, block the pedal down with a piece of wood and sometimes that will break it free.
I had a 2110 and 1900 and each came with a wooden block to use to force the pedal down over the winter or during storage. It's in the owner's manual and explains how to put the wood between the floor and arm of the clutch pedal. Just stuff something in there to push the pedal down while you figure out what to do. You should be able to get that free.
/ clutch stuck, Ford 1920 #37
This is an old post, I was surprised at it popping back up.
There is a method to this madness, lol. I hope when you say that you are keeping it in the mid gears and slamming the brakes, WITH THE CLUTCH PEDAL DEPRESSED? The object is to put a load on the clutch while it is depressed, so when the load that is being created by pressing the brakes is transferred up the driveline, the weakest point is the clutch disc that is only "rusted" to the flywheel. A rusted joint is easier to break than a solid metal one). If you are trying to loosen the clutch disc from the flywheel with the pedal in the up position, then the pressure plate is carrying the load that it is designed to carry and you are fighting both the pressure plate and the rusted flywheel. You want the clutch disc to slip when you apply the load of the brakes and or a plow, boxblade, or other loading method.
Hope that helps,
David from jax
I thought it was funny when Sixdogs said that "this is very sound advice", since it was coming from Soundguy, lol!
6'4" X 10' UTILITY TRAILER (A64277)
6'4" X 10' UTILITY...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
Metal John Deere Birdhouse (A64127)
Metal John Deere...
